Bass traps needed
Sounds about right. You may wish to experiment with some RS60 in unseen areas just to see if it makes a difference but glad its been successful.
Mmmm - an acoustic headboard? I could set up business selling those I recon'
The traps will be fine free standing, they would only make a controlable differeence securing them (acoustically) if you was making a sealed air tight unit.
I would definatley recommend using some rockwool if you still are having bass issues
I got 2 GIK 244 bass traps for my room corners, but due to domestic arrangements have put them behind the speakers for now.
A small improvement, slightly clearer sound all round. The speakers are on the long wall, so no issues with reflections off side walls.
I wasn't having bass issues previously, I just used room treatments to improve the sound.
The GIK 244's were a consideration and looked to be the most effective, more so than foam but unfortunately a little too large for my bedroom.
Acoustic headboard's worth considering as the bed's in one of the corners :grin:
