Apologies if this is a naive question, but would it be ok to use the Yamaha RX-V467 with the B&W MT-30 speaker system ? I would use a Sony BDP-370 for bluray AND for music CDs.
For a similar budget, is there a better amp ? I would only really be using 5.1 channels and for a 70/30 mix of home theater and music.
A friend of mine is using the B&W MT-30 with the RX-V567 and it sounded great (or at least it did to my inexperienced ears..!). I assume the difference between the 467 and 567 is that the latter has 7.1 channels which I won't need. However, I noticed that when he switched from bluray to music CD, the sound was immediately very bright and lacking bass, until he adjusted the crossover manually using the remote. Is this always necessary or would a better amp / set-up resolve this issue automatically ?
Thanks in advance for any advice from anyone.
Jay
Jay
