B&W 685 S2 vs B&W 683 S2 vs Room Size
nonpattern
Hi all,
I'm looking to find out it is worth to upgrade from B&W 685 S2 to B&W 683 S2 considering my room size is 15.8 ft x 12.5 ft. My current amplifier is Cambridge Audio Azur 651A, but that can be upgraded as well. I am only thinking about sound quality, not cost here.
Will I get a lot more from B&W 683 S2 or do they need a bigger room to really sound good?
Thanks!
Cambridge Audio Azur 651ACambridge Audio Azur 651A
manicm
Stick with the 685s, the 683s will definitely need more space to do them justice. You can also consider the 684 S2 - B&W seemed to design these with smaller rooms but from reviews I've read you really need to audition them first - preferably in your home - check with your dealer if you can borrow them over a weekend.
nonpattern
Thank you all for the replies!
manicm, 684 S2 got not so great reviews, so I'll just stick to what I have for now.
Reijer, thanks for suggestions, but I'll keep the 685s2s for now.
