The_Lhc said:John Duncan said:Now this looks interesting. Digital only input, 50w a side.
Only one input though, I don't get it, it's like building a sonos connect:amp from bits.
bigblue235 said:The_Lhc said:John Duncan said:Now this looks interesting. Digital only input, 50w a side.
I thought that too, but I guess it's better/cheaper than buying a Connect + AE if you want to go the Airplay way.
The_Lhc said:Well, you still need the Apple TV, so it's not going to work out that much cheaper and you're then left with a system that can ONLY play from Apple sources. Dunno, it just seems like a single input dac and amp, which isn't that interesting at all...
oldric_naubhoff said:The_Lhc said:Well, you still need the Apple TV, so it's not going to work out that much cheaper and you're then left with a system that can ONLY play from Apple sources. Dunno, it just seems like a single input dac and amp, which isn't that interesting at all...
but you don't need to connect it to an Apple TV if you don't want to be restricted to play from only Apple sources. I'm pretty much sure some peoples favorite Sosos would be a good match too.
The_Lhc said:oldric_naubhoff said:The_Lhc said:Well, you still need the Apple TV, so it's not going to work out that much cheaper and you're then left with a system that can ONLY play from Apple sources. Dunno, it just seems like a single input dac and amp, which isn't that interesting at all...
Well I appreciate that but then where do I plug the turntable in?
oldric_naubhoff said:The_Lhc said:oldric_naubhoff said:The_Lhc said:Well, you still need the Apple TV, so it's not going to work out that much cheaper and you're then left with a system that can ONLY play from Apple sources. Dunno, it just seems like a single input dac and amp, which isn't that interesting at all...
obviously this product is targeted at the market who wee on analog sources, don't you think?
The_Lhc said:oldric_naubhoff said:The_Lhc said:oldric_naubhoff said:The_Lhc said:Well, you still need the Apple TV, so it's not going to work out that much cheaper and you're then left with a system that can ONLY play from Apple sources. Dunno, it just seems like a single input dac and amp, which isn't that interesting at all...
Or any other source then? Just seems stupidly limited, at least stick a USB input on there or something.
John Duncan said:My thought was that it would fit nicely on my computer desk shelf. The one below my iMac, with its digital output...
oldric_naubhoff said:The_Lhc said:oldric_naubhoff said:The_Lhc said:oldric_naubhoff said:The_Lhc said:Well, you still need the Apple TV, so it's not going to work out that much cheaper and you're then left with a system that can ONLY play from Apple sources. Dunno, it just seems like a single input dac and amp, which isn't that interesting at all...
limited it is indeed.
as for the lack of a USB input; you can always get yourself a USB/spdif converter (like hiface from M2Tech) if you're really in dire need of plugging your computer into this thing and your onboard soundcard doesn't include a spdif out.
The_Lhc said:oldric_naubhoff said:The_Lhc said:oldric_naubhoff said:The_Lhc said:oldric_naubhoff said:The_Lhc said:Well, you still need the Apple TV, so it's not going to work out that much cheaper and you're then left with a system that can ONLY play from Apple sources. Dunno, it just seems like a single input dac and amp, which isn't that interesting at all...
Or I could just buy something else a bit more flexible, see what I mean?
BenLaw said:Chebby, why have you linked to tvchoicemagazine?
http://www.tvchoicemagazine.co.uk/sites/default/files/imagecache/interview_image/intex/jessica_hynes.png
BenLaw said:Tortuous and opaque, but very clever I'm sure. I watched most of it but can't say it was uppermost in my mind after the summer.
