I have the following set up having just brought the CM's / PV1 today, but need a little help on the Amp front as a little new to this.
B&W CM7's (front), B&W CM1's (rear), B&W VM1 Centre, B&W PV1, SKY HD, PS3, XBOX 360 Elite, QED Cables, Samsung LE40M87BDX HDTV
First move into a real set up having just had a one box solution before (sony dav 880) and will mainly use for 75% skyHD, 24% blu-ray /DVD / PS3 games, 1% music (if that). I listened to a kef 2005.3 & Denon 1909 set up in a listening room and was dismayed how hollow it sounded, no real depth to the experience. A little concerned that if i don't partner right amp then may not get the best from CM's either. I like the look of the Yam RX-V1900 or the Denon 2310, but open to other options. Budget is around £800 to £1000. Want to try and get a short list and demo a few. should i be concerned if going end of line(V1900)? Anything i should really avoid? Seems to be new version of amps every six months which does not help!
VM1 is due to space constraints and the one concession to wife on 'boxes and cables' . . . .
