plastic penguin
Vladimir said:I'm not saying go and blind buy an amp. We are discussing here loosely what will fit the budget and the technical discussion should filter out unsuited candidates performance What you plasticpenguin heard in your room, with your gear, with your music, with your listening preferences, is of no value to the OP because he will hear something completely different with the same gear. Like you said, best for him to hear for himself, if
It has more value than someone with no experience of the combo, relying solely on promo and technical stuff.
If you think paper specs are the bible then that can create more issues than it solves, hence why this segment has dragged on for so long. There's no amount of literature that can substitute hearing it for yourself.
