Amplifier needed (Arcam FMJ A19, Roksan Kandy K2...)
Tzutzu
12
You're right again. Life taught me that the best gear for me is the one I like and I can afford. And as my carpenter told me once (responding to some complaints of mine): Never seek for perfection...
Which brings me back to my questions. I understood that A19 lacks treble and bass controls. Has anyone felt the need for those?
P.S. I've just read the A19 whathifi review in which it is best paired with my long awaited 8200CD
BigH
114
7
18,595
It really depends on your taste, reviews are just a rough guide. I have heard the A19 and I would say its refined but maybe a bit lacking guts, so maybe better for classical than rock. I would def. try the Marantz Pearl Lite and Creek A50, pity WHF did not inc. them in their group test.
The Mad One
19
Sorry i have to disagree with BigH that the arcam A19 is only suitable for classical, FWIW i think the arcam sounds amazing with any type of music it can give many amps costing twice the price a run for its money.
It also gels extremely well with the KEF LS50 Speakers and my guess is it will suit any r series kef speakers.
if you can give it a listen as well as the Roksan and the Creek Amps
Good Luck with your mission
Tzutzu
12
I would try each and everyone of them. But unfortunately the closest hifi shop is at 300 km away. I even forget about the distance and go there but my job wouldn't let me.
The Pearl Lite - I've decided to change the brand (nothing to complain about though, just so). As for the Creek, what I've read till now it is not so convincing.
What about Roksan? Do you have any experience with it?.
The Mad One
19
I did listen to the roksan B4 deciding on the the Arcam, the roksan is a very fine Amp and go's extremely loud.
but for me i prefer the arcam for refinement and the vast sounstage it throws at you and can go loud as well.
regards
BigH
114
7
18,595
Have you read the reviews on the Creek website?
As far as I know Creek have had a long and good rep. Arcam had a good rep years ago for amps like the Alpha 9 but not so much lately. To be honest I don't think there is much between both seem to be fine British man. with well made products, certainly my Arcam has lasted 20 years without any problem.
It really depends what sort of sound you are after. I hope to hear the Creek on Saturday.
markiedee
7
The arcam definately has guts i can't believe how powerful it is for 50 watts, the soundstage it projects out is big and wide and envelopes me in sound. On volume level 33 is sufficient for me but on volume level 40 is enough without the need to go any higher.
BigH
114
7
18,595
Here is an extract from the Hi-Fi News group test "The most musically enjoyable and the least coloured sounding of the group, the Creek gave unalloyed pleasure. It’s similar to the Arcam in the wonderfully engaging way it performs, yet has an altogether cleaner and more insightful nature.
For example, ‘Morning Child’ sounded magnificent, the amp showing its taut, tuneful bass, glassclear midband and sweet, spacious
treble to best effect. Powerful and detailed, this amp nevertheless really impressed in the way it strung all the strands of the
mix together in so natural a way. Vocal phrasing was on another level to all others in the group, and the percussive piano shone through the
busy mix like no rivals here."
As I say it depends what sort of sound you want.
BigH
114
7
18,595
The Mad One said:
Sorry i have to disagree with BigH that the arcam A19 is only suitable for classical, FWIW i think the arcam sounds amazing with any type of music it can give many amps costing twice the price a run for its money. It also gels extremely well with the KEF LS50 Speakers and my guess is it will suit any r series kef speakers. if you can give it a listen as well as the Roksan and the Creek Amps Good Luck with your mission
Actually I did not say that, I said maybe better for classical than rock, thats the impression from my demo.
Also from WHF review "The overall presentation feels a bit too sedate, and there’s a sense of wanting to urge the Arcam on just a bit more to a more exciting and involving performance."
Tzutzu
12
Well, good morning
Sorry for living the discussion so abruptly yesterday evening. But just as I mentioned my job and it stroke me with some serious things that had to be done. Now everything is nice and quiet so I managed to read the previous posts.
@The Mad One and markidee: So I wanted to ask The Mad One and markiedee if they at any time felt the need for treble and bass controls on this amp :quest:
Thought about speakers. I would suggest going with a compact floorstander. The reason is if you're putting bookshelf speakers on dedicated stands, they'll take up as much room as a floorstander. The only concern about floorstanders, if the room is very small, they may be a little overwhelming in the bass. But with smallish to medium size rooms I'd look at floorstanders. They look nicer than having a small speaker stuck to a drainpipe. That is only my personal view.
markiedee
7
Tzutzu said:
Well, good morning
I don't feel like i need treble or bass controls to as everything sounds right to me, i can't really speak for anyone else. It would really be good if you could get a demo to see for yourself but i have no complaints in that regard. Bass is punchy midrange and treble nice and crisp and is a really enjoyable and non fatiging sound.
Tzutzu
12
@PP What do you have in mind? Deep in my soul, without having any significant experience, I thought about floorstanders. Sometimes, bigger is better. Although R300 look so good...
@markiedee That's very good to know. Again, I count on your personal experience, a demo being out of the question in the near future.
Neat Motive 2, Kef IQ50 and my favourites Totem Arros. These should work beautifully with Arcam, Roksan and Creek
tonky
36
tone controls - some people like the flexibility of tone controls - i have found a slight degadation in sound quality when you use them so (inmho) don't use them. Others may think different!
tonky
BigH
114
7
18,595
Tone controls I don't tend to use them, however on a few modern cd recordings the sound can be a bit bright +/or boomy.
Tzutzu
12
I can see a tendency in avoiding tone controls. An equivalent of Source Direct. Another step forward.
Tzutzu
12
Ok, but are they hard to find or is it my fault? I wouldn't go second-hand.
danrv
14
tonky
+1 on that. I tried using them on my Rotel RA-01 to tame a little brightness but noticed the sound was not quite as clear as with tone defeat. I now have a Roksan Kandy K2 that has no tone or balance controls and my hifi has never sounded better. Good equipment that's well matched shouldn't need them.
The Arcam A19 looks a good bet as long as partnering equipment isn't too laid back.
Depends where you live. The Totems can be tricky to track down, but well worth the effort IMHO.
BigH
114
7
18,595
danrv said:
tonky
Yes WHF review does touch on partnering equipment needs careful matching, they seem to think the Kef LS50s were a good match but I found the LS50s were not very good at low volumes.
Tzutzu
12
Hello danrv
Thank you for being here. It would be very interesting to know if you had any experience with your amp and Audiolab's 8200CD. In case you didn't read the whole story, I have to choose from this range of amps in which I included FMJ A19, Kandy K2 and Evo50. Till now, Arcam is a bit in the lead. I would like to know your opinion.
Tzutzu
12
@BigH You're right. I prefer low to moderate volumes, so the speakers should comply with that. As PP said, a pair of compact floorstanders may be a better choice.
BigH
114
7
18,595
Yes FS maybe better as generally more sensitive but I think they do need some space, ideally about 3 feet away from walls and corners otherwise they can be boomy. I prefer standmounts.
