ADM9RS or good British passive system?
JohnBr
Hi, I joined the forum to seek some advice on a new system for the new year. I used to own a nice system a few years back but gradually lost it as we moved homes.
I'm looking to get a good sounding system to play from my Mac and I'd like the speakers to be modest size wooden boxes (ideally with grilles) to fit in with the room. The Kef LS50s sound like a great option, but just not to my taste looks-wise!
I have been reading about the AVI ADM9RS which sound like a good option. I have also looked into more classic speakers like Harbeth, Spendor and Proac with a British amp around the 1k mark.
So, how would the AVI compare to something like the Harbeth P3ESR/M30.1, Spendor S3/5R2, Proac D1/D2 with something like the Naim 5 or XS? I was looking at one of the mini DACs like the dragonfly or meridian as they are very compact and supposed to be good. Or, finding an amp with a DAC built in.
I realise the AVIs are much cheaper due to less boxes, but how do they compare sound wise? I read that they lack the bass and also top end sparkle of a passive system, but do they sound better overall? I listen to a wide range of music including jazz, soul, folk, electronic.
I plan to start some demos, but it's hard to demo them together. Any advice would be great!
The AVI adm9 speakers provide the speakers, amps, remote controlled pre and dac + power and connecting cables for £1250 delivered in UK.
All the speakers you mention are by decent companies but you won't match the sound quality of the ADMs for any where near the price. Your music choice would tend to suggest that the ADMs would suit you very well. They certaily are not bass light.
Since moving to AVI myself I cannot stand listening to passive systems for very long at all and some of my friends have spent much ££££££££s and time putting their systems together.
Good luck in your return to stereo.
I don't know how they compare but you do get a lot with AVI's products. Best to head over to their forum for more info and some unbiased advise ...
Alternatively, I find Belcanto's integrated an interesting option amongst amplifiers, as are cyrus with their DAC/Integrated. Either would probably make a lovely system with Harbeths or Kef's.
regards
You have to remember that the Naim/Spendor/Harbeth etc systems will probably outperform the AVIs, simply because their component parts are more expensive and therefore (hopefully) of better quality, so it isn't really a fair comparison.
You really should audition all your choices, preferably at a dealer so you can make a direct comparison. Also worth considering, and much cheaper, are the new Quad active speakers, as well as those from Nubert (www.nubert.de) which get wonderful reviews in Germany. They're available on a 30 day trial, and apparently Nubert pay for return postage.
More expensive, but said to be stunning, are the ATC actives, which to a large extent are the reference for acive monitors.
Another alternative rarely mentioned on this forum are the Linn speakers, such as the Majik series, which can be upgraded to active speakers.
regards
Unbiased advice as in the advice you get on the Linn forum, the Naim forum, or any other manufacturer's forum. I think you mean highly biased
Welcome to the forum, and happy new year.
I can't comment on the AVIs as I haven't heard them, but my advice would be as follows:
- Nobody here can tell you what you will prefer with any certainty.
- Owners of any kit will often tell you there is nothing like it.
- What constitutes VFM is very subjective.
- Don't buy "on hype" and make sure you listen for yourself.....and trust what you like.
- FWIW. I like your choice of speakers, but would include Sonus Faber, Kef R Series and Vienna Acoustics; for amps, you might also like to consider Sugden, Arcam, Musical Fidelity, Creek, Pathos and Electrocompaniet.
The original ADM9 and ADM9T speakers were a bit bass light but the newer ADM9RS versions are much better in this respect. As with any small standmount speakers to get really deep bass you'll need to add a good quality subwoofer.
drummerman said:
...Best to head over to their forum for more info and some unbiased advise ...
:rofl:
AVI make some cracking speakers though. Well worth a listen to see what you think before spending more money elsewhere.
Ah alrighty then, I was being a little sarcastic but its just the way they are, hey ho.
There are some very knowledgeable people over there so it does make for interesting reading if can see through the gospel and the little man himself is not half bad either.
Wheareas AVI had the domestically acceptable active market almost for themselves over the last few years since the first incarnation of the innovative ADM's (disregarding stalwarts like B&O/Meridian for a moment), there are now admittedly a few more options with probably yet more to come. If nothing else it shows what foresight the company has and how they embrace wider technology as part of an integrated home entertainment solution. No mean feat for such a small company ... albeith one with years of experience.
The new Quad actives look interesting but as chebby, I'd want a size up. Nubert, as mentioned look good too.
Nice that there are so many options and it shows that companies still take hifi serious.
regards
They indeed offer free return shipping as long as you are located within the European Union (which unfortunately is not my case...).
More expensive doesn't necessarily mean better if there are more efficient ways of achieving an end result. I'm not taking sides in this particular argument, but I think it is important not to risk spreading the misconception that if you throw money at kit it will be better (I do note your addition of 'hopefully' in parentheses).
Thanks for the replies. I really do need to get a demo of the various options.
Has anyone made any direct comparisons between the ADMs and similar passive systems to the aforementioned?
Also, I thought about the Nad D3020 to go with something like the Harbeth, Proac or Spendor as it's a neat, low cost unit and the speakers look to be easy to drive.
I heard the 9.1Ts some time ago and wasn't that taken with them because I felt they lacked bass, despite their undoubted abilities elsewhere. I understand that the later models have addressed this, which would make them an extremely competent system, particularly at the price, provided the number and types of inputs is appropriate for your needs. I think, especially with their direct sales model, you would probably need to spend double in order to match them with conventional separates. In that regard, I would be looking at Spendor and KEF with a nice chunky amp from Naim or Creek - I liked the NAD but I don't think it's in the same league.
I am not convinced by claims that they cannot be matched at any price (or indeed the effect of active crossovers) as, for example, I felt that the PMC DB1S-AII (a powered passive) were better in a direct comparison, albeit at almost twice the price. Neither could I accommodate them anyway as they're a bit chunky; their gorgeous little DM5s would be much more suitable for me in this regard, though they lack the preamp functionality of their bigger brother, and would definitely need a sub I think - the omission of a sub out on these was a mistake to my mind, but I guess they are aimed at a different market.
JohnBr said:
...Has anyone made any direct comparisons between the ADMs and similar passive systems to the aforementioned?...
The ADM's like many other good active speakers from companies such as Genelec, Quested or the Event Opals sound clearer than any passive speakers that I've heard.
The closest that I've ever heard passives sound to good actives is probably some Vienna Acoustics speakers driven by a pair of Cyrus monoblock amplifiers. Very impressive but silly money though and still not quite as good as some of the high quality active speakers availible at a lower price.
John Duncan said:
I heard the 9.1Ts some time ago and wasn't that taken with them because I felt they lacked bass, despite their undoubted abilities elsewhere...
I thought the old ADM9.1T model was a bit bass light too. The smaller passive Neutron 5's sound like they have a bit more bass than the old ADM9.1T's (although they're not quite as 'tight' sounding).
Personally I wouldn't want any bookshelf speaker without adding a subwoofer. They always seem to either have too little but 'right' sounding bass or they have enough bass but it sounds overblown, boomy and out of control. IME the only way to get good quality tight sounding deep bass is with very big full range speakers or small bookshelf sized speakers partnered with a sub.
Well there are also active speakers with DSP and Bass EQ as another design option to get superb bass without needing huge cabinets, or separate subs.
JMac
I've made direct comparisons between the old ADM9.1T and a Chord QBD76/ATC SIA2-150 + SCM19, also a Cambridge Audio 640 cdp/Musical Fidelity A5/PMC DB1i. The ADMs sounded quite similar to the Chord/ATC setup but despite the Chord/ATC kit being mine I had to admit the ADMs were better in many regards, like JD though I felt the ADMs were a bit too lean. The sound of the CA/MF/PMC setup was quite different at the bass and treble ends, more of each compared to the ADMs - while I would've happily took the extra bass I found the treble too forward. The latest ADM9RS is, IMO, a large improvement in every area on the earlier 9.1T - more bass, greater clarity and smoothness, more treble detail. They still benefit from the sub though, it turns them into something extremely impressive.
Hi John,
Cannot comment on the AVIs as not heard them, but did briefly consider ditching my pre/power for a pair. My B&W602S3s have served well in a 7.1 set up but were a bit unruly in their new role in the bedroom hifi. Home trialed some 5* award winners and they were Ok with hi res but aweful with anything compressed - no bass at all and shrill. Was going to try Dalis & R100 but was talked into trying some Dynaudio DM2/7s. The advice was good as truely superb at the price IMHO but rarely mentioned in the mags. My Meridian kit is singing sweetly once again with well defined tight bass lines and very musical despite still running in. Combined with a Creek 50A with the Ruby DAC module would cost a tad more than the 9RS. Plenty of simmilar combos out there. Regarding the DAC, I use a rPAC from my iMac and very pleased. Tried it in the hifi and sounded thin so beware of DACs designed for headphones. The irDAC/A19 would be on my shortlist with the Creek combined with Dyns, R100 and Epos for starters.Happy auditioning.
Craig M. said:
Mine have replaced some much more costly separates and sound better to boot.
Hi Craig
How's things?
How would you say the 9RS compare to the Opals?
Sorry about going off topic.
Matt
I suppose it depends where you think the bulk of the story in a musical piece lies. I have some of the smallest speakers that are on the market probably, but given the setting where they sit in my room, I never feel as if I'm missing out. Seeing as the bulk of the music is in the midrange, as long as the frequencies at either end are well catered for, then you can overlook the compromises pretty well. I've never felt as if I was missing out, nor that I need to buy a sub to fill in the gaps. Think that's probably testament to the skill that went into the DC4's design.
If only they made a smaller sub, it's a bit if a beast to hide!
I'm not a big bass head though, so could probably do without a sub. I like speakers to be really insightful, loads of detail and separation of elements. Pethaps the AVIs would suit in that regard.
Im warnung more towards them due to their sheer simplicity. Has anyone not liked them for any reason other than bring a tad light on the bass?
When it comes to reasons why some people dislike them, 'being a tad light on the bass' is well down the list.
