Picked this up the other day and no where on the packaging did it mention it was mono. Will it play on my stereo TT ok?
emcc_3 said:Picked this up the other day and no where on the packaging did it mention it was mono. Will it play on my stereo TT ok?
6and8 said:It should play, no problem. In fact, in the old days some album covers would have a message saying albums could be played with both mono and stereo cartridges. Whether you enjoy listening to mono is another thing. In my collection I've a few older albums that are mono - Dylan, Rolling Stones, Who, Beatles, Jefferson Airplane - the beat goes on. Being mono they sound more of that era. At that time I didn't have a stereo set up but my parents' (mono) Dansette to play my records on. It's all a matter of taste, I've some stereo versions of earlier albums that don't sound that great.
MajorFubar said:It's extremely unlikely it's been recorded using a mono cutting head, so it will play absolutely fine with a stereo cartridge. The original '65 pressing would be a slightly different kettle of fish, though it would still play.
In the unlikely event your amplifier has a 'mono' button, it's worthwhile engaging it when listening to a mono LP played by a stereo cartridge. Rumble, surface noise and various kinds of tracking errors often manifest themselves out of phase, due to the way stereo records are cut (sum+difference). With a record that's mono to start with, you can make use of the mono button to greatly reduce them.
emcc_3 said:I believe you can rig a switch using 2 y adapters to achieve the same mono effect.
Al ears said:emcc_3 said:I believe you can rig a switch using 2 y adapters to achieve the same mono effect.
I very much doubt it. If this cut was by Mofi or reputable presser it will be have cut using a mono process. This doesn't mean you cannot play it just not optimally.
MajorFubar said:Al ears said:emcc_3 said:I believe you can rig a switch using 2 y adapters to achieve the same mono effect.
I took it to mean in place of a mono switch. I still highly doubt it will have been cut with a mono head. The equipment to do so was skipped decades ago.
Al ears said:Note the recent release of The Beatles in mono and the Ortofon mono cartridge conjunction.
MajorFubar said:Al ears said:Note the recent release of The Beatles in mono and the Ortofon mono cartridge conjunction.
...yeah which was normal cartridge with a normal-sized stylus tip wired internally for mono. Maybe it was 'kind of' mono if it really did lack the second set of coils needed to track vertical movement, but it was nothing to write home about and was designed only to increase the hype surrounding the mono masters being available on vinyl for the first time in decades, not because you needed it to play the records. The technical details of the cuts (that I'm not now finding on the internet, but which I did read at the time) confirmed the lacquers were all cut with a regular stereo Telefunken head.
Al ears said:MajorFubar said:Al ears said:Note the recent release of The Beatles in mono and the Ortofon mono cartridge conjunction.
Irrespective of how it was cut I wouldn't be wasting a nice Shibata tipped moving magnet on it. To hear it as it should be is difficult these days as mono buttons are a thing of the past and you'd be better off with a real mono cartridge.
If you cannot do this then stick with a stereo version of the LP would be my advice.
thescarletpronster said:I was thinking about this yesterday, and wondering whether it might actually be the case that recent reissues in mono might actually be cut by a stereo head but with exactly the same audio on both channels, giving the effect of mono reproduction but designed to be played using a stereo stylus.
It would make sense, because how many of the people buying mono reissues (rather than having the originals) will have a dedicated mono system?
It would be interesting to know, if anyone has any info about this.
