Hope someone can help me in deciding which speaker cable to buy for the following cinema system:
1. Pioneer sc-lx82 a/v receiver
2. Pioneer bdp-lx52 blueray player
3. Pioneer pdp-lx5090 plasma tv
4. Monitor audio bronze br5 a/v package
As you can tell i am a great fan of pioneer so therefore i need to choose the right speaker cable to make my new system really sing. So therefore i need to know which is the better cable manufacturer, is it QED or CHORD COMPANY or which manufacturer's cable will sound better on my system. Also if i use a expensive cable like the chord oddysey 2 for the 2 front speaker's including the centre speaker and then use a less expensive cable like the chord rumour or even cheaper chord silverscreen would this be ok or not. I am looking for a cable that is very clear sounding and also has a lot of tight controll on the bass and the treble. Like i said i would appreciate as much help or advice as possible because i just do not know where to begin. Is it really worth me bi-wiring the front and centre speaker's with cheap cable (chord silverscreen) or not and instead use single more expensive speaker cable (chord oddysey)?
P.S. Most of the hi-fi shop's recommend that i use the chord company cable stating that they are better than then the qed cable's is this true or not. Thank's
DR KAY
DR KAY
