Which dock?? Bose or B&W ???
atkins4725
175
Im after a gd dock for the ipod and was cosidering either the 'BOSE sound dock portable' at 300 or the 'B&W zeppelin" at 400. I've heard the Bose in action and to be honest it sounded better than my setup at home.
Is there much difference in sound quality between the Bose and the B&W for the extra 100?
After hearing the Bose i was shocked at how good it sounded and as far as the B&W goes i've not heard it myself yet. I was going off the 5star rating that it's been given.
Any that u would reccomend???
May be totally irreverent, but if it's for personal use you could get a stunning headphone amp/headphones for this money...
Sorry I'm slow or unknowledgeable, probably both, but what does SQ mean?
Both are expensive for docks and you will probibly be better off with separates. But honestly the bose dock is utter tat (imo). The zepelin nails it in every regard. If you must have one of the two definataly buy the zepelin. It looks and sounds so much better.
Yeah sorry, it mean sound quality.
I used to do alot of incar audio stuff and thats what sound quality is refered too. 'SQ' sound quality - 'SPL' sound pressure level, etc.
But then i grew up, lol.
No problem, I'll remember that one next time I'm texting about sound quality.
As to your last question though I seriously doubt many people have spent time comparing the two. If you can test them together in the same shop, that would be ideal. If I were you I would spend my £400 far differently...
Except that I can't think of a better looking system, at that money, than the B&W. It's gorgeous. The only comparably gorgeous alternative is the much much more pricey Meridian F80. Now I want one of those!!!
Did you consider myÿsuggestion of headphones? I'm talking equaling £2-3000 systems for £400. Or do you have friends?
the b&w rocks and goes deep - easilyfills a good sized room - great piece of kit - the bose is no where in comparison - you could also look at the fatman kit
"the b&w rocks and goes deep - easilyfills a good sized room - great piece of kit - the bose is no where in comparison - you could also look at the fatman kit "
I second that! Get a fatman with some decent speakers from ebay. But again if it has to be the comprimise of a really compact dock. Nothing for the money gets close to a Zeplin.
matengawhat:easily fills a good sized room
.....with tat, that was my issue with it. Sucked all the midrange out. Or maybe I'm just deaf, since everybody else seems to like it.....
The 'Bose' doesn't seem to be getting much credit. I thought that sounded pretty good, i cant wait to here the 'B&W' now.
Im using the latest version of itunes if that makes any difference??? and it's all being copied to my laptop using 'WAV'.
Im not interested in an amp and headphone setup but i think i'll give the 'fatman itube carbon a look' from what i've been reading it can be bought with out the speakers for 100 less which brings it down to 250 for the dock with just the speakers to buy.
If i was to go for the 'fatman' what speakers would i be lookin at??? something like the 'tannoy mercury f1's' or is it worth shelling out and going for the 'B&W 685s'
I don't know if the Fatman is able to feed the B&W's with enough power. I actually - coincidently - heard a demo of the fatman with Monitor Audio BR2's and I thought it was a wonderful match. MA's can sound a bit harsh on the treble but not in this combo. The BR2's don't need much juice so that helped too I suppose.
What about the new Dali's mentioned in this months mag as 5* marvels. Dali Lektor 1. Sounds like something you'd buy in Ikea, but apparently they sound fab. £250 a pair but you'd be bound to be able to chip that a bit.
http://whathifi.co.uk/News/New-Dali-Lektor-speakers-due-out-this-autumn/
I love our Bose (the 2006 model in white) and the sound quality is amazing for the price - on the other hand, you could go with something like a Pioneer A-400 with Wharfedale Diamond 9.1 speakers and it would be a hell of alot better for much cheaper!
Oh and I repeat, DO NOT go for the B&W speakers with the fatman dock...DO NOT! Those speakers need atleast 70watts of decent, high ampage power to get the best from them! Anything with a sensitivity of 89db @1w/1m or under is a no-no...try the Monitor Audios afore mentioned.
Hughes123:Oh and I repeat, DO NOT go for the B&W speakers with the fatman dock...DO NOT! Those speakers need atleast 70watts of decent, high ampage power to get the best from them! Anything with a sensitivity of 89db @1w/1m or under is a no-no...try the Monitor Audios afore mentioned.
Indeed. I can vouch for the Fatman iTube with the MA BR1's and Atacama stands....
Don't have it any more but it was an excellent set-up. (The Fatman is a great headphone amp as well.)
Ok, so upto now i see options as either:
B&W Zeppelin - 400
Bose sound dock - 300
Fatman Carbon ( without speakers ) - 250. With a pair of the following speakers
DALI Lektor 1 - 100watt - 250
Tannoy Mercury F1 - 50watt - 110
Monitor Audio BR2 - 100watt - 100
Wharfedale Diamond 9.1 - 100watt - 150
Roth Audio OLi1 - 100watt - 100
Am i right in sayin the pioneer amp that was mentioned was made in 1990???
