Looking for a method to store my AKG? Seen some stand but are they stable enough and worth the money? What other methods you do use? Hooks? Bags? Drawer?
insider9 said:Looking for a method to store my AKG? Seen some stand but are they stable enough and worth the money? What other methods you do use? Hooks? Bags? Drawer?
DougK said:I've tried all manner of stands with varying degrees of success, (best to blue-tack the stand base to stable furniture). But I now use these: https://www.amazon.co.uk/Konig-Meyer-Bracket-Holder-Headphone/dp/B005MZKCJM
Personally I wouldn't go the mannequin head route as I prefer to keep the clamping force tight, therefore, I store mine in the un-stressed position, (my main go-to headphones are HD650 and SR225).
muljao said:You could do what I do and put them some place different every time you finish using them, therefore setting out on a new adventure every time you want to use them, sometimes not finding them for days and wondering why you put them in the microwave
I hope not, I've always been bad at misplacing things. I am also very bad with peoples names. It's actually terrible because people think you are really insincere when you avoid there names, even though you've known them all your life. Coat hanger sounds good. I may copy you on that oneAl ears said:muljao said:You could do what I do and put them some place different every time you finish using them, therefore setting out on a new adventure every time you want to use them, sometimes not finding them for days and wondering why you put them in the microwave
Do I detect a hint of early onset Alzhiemers?
Mine currently hang in a wardrobe on a coathanger.
Travelling B&W P7's reside in their supplied and very-ladylike travel / clutch bag
DougK, thanks that's the most suitable solution for me so far.DougK said:I've tried all manner of stands with varying degrees of success, (best to blue-tack the stand base to stable furniture). But I now use these: https://www.amazon.co.uk/Konig-Meyer-Bracket-Holder-Headphone/dp/B005MZKCJM
insider9 said:DougK, thanks that's the most suitable solution for me so far.
Is there a way to fix it to a side of a hifi rack as opposed to screwing it in? Do you reckon it would be ok to velcro it?
That's not bad at all. Especially as you could mount it on mic stand (not that I own one anymore) but flexibility in terms of placement is probably worth the extra.DougK said:insider9 said:DougK, thanks that's the most suitable solution for me so far.
Bracket construction in conjuction with headphone would be too heavy for velcro methinks. Here's a variation on the theme which might work for you:
https://www.amazon.co.uk/Konig-Meyer-Holder-Table-Headphone/dp/B005MZKD8M/ref=pd_sbs_267_3?_encoding=UTF8&psc=1&refRID=8RX361GKZTRZC5VRF2NH
Expensive, but good quality pro-kit.
insider9 said:DougK, thanks that's the most suitable solution for me so far.DougK said:I've tried all manner of stands with varying degrees of success, (best to blue-tack the stand base to stable furniture). But I now use these: https://www.amazon.co.uk/Konig-Meyer-Bracket-Holder-Headphone/dp/B005MZKCJM
insider9 said:That's not bad at all. Especially as you could mount it on mic stand (not that I own one anymore) but flexibility in terms of placement is probably worth the extra.
Good thinking, thanksSamd said:insider9 said:DougK, thanks that's the most suitable solution for me so far.DougK said:I've tried all manner of stands with varying degrees of success, (best to blue-tack the stand base to stable furniture). But I now use these: https://www.amazon.co.uk/Konig-Meyer-Bracket-Holder-Headphone/dp/B005MZKCJM
Command strip would hold it and give you flexibility in moving it.
DougK said:insider9 said:That's not bad at all. Especially as you could mount it on mic stand (not that I own one anymore) but flexibility in terms of placement is probably worth the extra.
They actually do one for a mic stand as well! Konig-Meyer do many variations of the standard bracket, have a trawl on Amazon, I'm sure you'll find something which suits your exact requirements *good*
