What is this ?
Gazzip said:
Vladimir said:
Gazzip said:
So, let me get this straight, the affect of the equivalent of 6 bags of loft insulation in my listening room is practically unmeasurable, but two door handles on top of my loudspeakers will make a difference? You are having a laugh.
Scattered secondary reflections from the speaker baffle edge are made more uniformly directional.
Alternatively you can stack felt to minimize them. This keeps manufacturing costs down.
A Gentleman's Guide For Improving Loudspeakers
I get that the science is there, and PMC do something similar with the rounding off of housing for the midrange driver from the SE range onwards. However, sticking a random piece of metal in a random position on top of your loudspeakers is not going to produce an infinite baffle effect. I’m sorry it just isn’t.
Like I said, better off buying a nice wood diffuser for the wall.
Indeed, although diffusers do need room to work, and in a small room, or if positioned too close to the listening position, can do more harm than good...
I wish I had two fish bowls on top of speakers to experiment with.
3UHSdBYP9yxAcSm4pxg10GAZEEkyZAwlCjdF93tCSam8lMFL9j_AoJ_IM74snNl03p8T=w300
I'll try a glass of water or a pepper shaker.
The fish bowls will not work. Whenever the fish swim about the overall resonant requency will change.
Good condiment plan but use a grinder set to fine milling. Do not a shaker as this will result in an over processed sound. If using the glass of water don’t forget to put a coaster down first to prevent ringing.
