Hi, I'm becoming a vinyl addict and i've been expanding my collection by buying a lot of used records (many of wich need cleaning).
I have been using the "AM Record Claner" (www.am-denmark.com). It's a cleaning fluid bottle that comes with a cloth- for the past year.
Talking to a couple of friends recently, they were shocked that I was using this as it would damage the records because of it being abbrasive (one of them suggested that this liquid could be used but dilluted...)
Questions are:
1) Is it safe to use this liquid for record cleaning?
2) Should I consider a cleaning machine, and if so, is there any good solution within a tight budget?
Thanks!!
cheers,
carlos
Questions are:
Thanks!!
cheers,
carlos
