pmconcierge
- Oct 22, 2013
- 0
- 0
- 0
Hence albums recorded at 45rpm and albums spread over 2, 3, or even 4 discs. Of course, if you want all this to come across as negative towards vinyl, you can choose to not mention it at all..Mastering for vinyl has always been a balance between loudness and playing time. The louder you want a song to be, the wider the groove needs to be in order to accommodate the larger amplitude of the album. Since there’s only a limited amount of usable surface area per vinyl disc, gaining dynamic range means sacrificing playing time, especially on a long playing (LP) record where upwards of six songs are often fit on each side of the disc.
I tend to find these qualities better on vinyl.Why is this important? Because when you compress music, the lower level details become more apparent and take an unnatural loudness relative to everything else. All the cues that give us space, ambience, soundstage, reverberation and room size are to be found in those low level details.
I don't think Mark's argument has merit. I think he's wrong. Hence why you'll never find a CD that sounds like its vinyl counterpart (decent mastering assumed).I think Mark’s argument has merit. I think he’s right. And if he is, one should be able to add the same compression techniques used by mastering engineers for vinyl, to digital audio and get the same results without having to transfer to vinyl.
marou said:What does interest me is the number of people (including friends whose views I'm reluctant to dismiss) who prefer vinyl to digital despite evidence to the contrary which I find quite persuasive. Paul McGowan is a hifi designer and enthusiast whose views should not be easily discounted. So tell me, why does a legacy device with an inferior dynamic range which with every play corrupts the vinyl on which it depends still command the loyalty of so many?
Thompsonuxb said:davedotco said:CnoEvil said:marou said:No offence taken - I don't really have a view, having never compared vinyl and digital under test conditions. What does interest me is the number of people (including friends whose views I'm reluctant to dismiss) who prefer vinyl to digital despite evidence to the contrary which I find quite persuasive. Paul McGowan is a hifi designer and enthusiast whose views should not be easily discounted. So tell me, why does a legacy device with an inferior dynamic range which with every play corrupts the vinyl on which it depends still command the loyalty of so many?
I suspect it may depend on the quality of the mastering on the CDs that they've listened to, as well as the source they have used for the comparison.
I have been lucky enough to have gone from decent TTs, to a great CDP to a very good streamer,......which has given me reasonable insight into how they all compare.
Very much to the point Cno.
The truly crazy thing is that most of the people I see and hear extolling the virtues of vinyl have pretty poor players, often third rate or worse.
My own experience was simply that the better the CD player and the better the record player the closer together they sounded in terms of sound quality.
For a brief period I was able to compare my own player, an SME20A/Red signature with the comparibly priced Wadia 860 and on some recordings the differences were actually difficult to hear, some modern, for the time, Deutsche Grammaphon DDD and DDA releases for example.
Edit for spelling.
Lol...... I think thats the reason for alot of the disagreement on this forum, some systems are just not up to the task.........
saying that is that just plain old snobbery though..... a cheap turntable can sound excellent by any standard if set -up just right.
and the noise floor (hiss) on a turntable no matter how good or dear it is is what stops vinyl from being a serious contender, but if you like that sort of thing then I can see the argument from the other side.
Electro said:marou said:McGowan says that a cd recording of a vinyl record is indistinguishable thus confirming there is no inherent superiority in analogue - interesting if true.
Yes it is true, I have done it many times myself and the CDR recording of an LP sounds identical to the original LP.
I have done several blind tests so that I did not know which one I was listening to and I found it impossible to hear any difference .
spiny norman said:See I was reading only last night that MP3s sound better than vinyl, and that really all one needs these days is an iPod and speakerettes. I guess all those turntable designers are wasting their time, then. :rofl:
drummerman said:I have another theory. Often, the noise floor of records is much higher than that of a good digital recording.
This 'fills' the gaps between notes, making for a more cohesive 'whole'. The brain has to work less hard to decipher and piece together the information.
Look at equipment like Cambridge Audio's 840's and other, very good measuring stuff. All the detail you could want but somehow it doesn't come together into a musical whole (for some people). Other equipment, perhaps not so acurate measuring, sounds more cohesive.
I am broadly generalising and I myself err on the side of accuracy for preference but could it be that there can be to much detail, to much stereo separation etc?
David@FrankHarvey said:Electro said:marou said:McGowan says that a cd recording of a vinyl record is indistinguishable thus confirming there is no inherent superiority in analogue - interesting if true.
In technical terms, that is impossible. I'm not saying it isn't, but bear in mind that CD has a brick wall 20kHz filter, whereas vinyl has been shown to have information up to around 60kHz.
Thompsonuxb said:Lol...... I think thats the reason for alot of the disagreement on this forum, some systems are just not up to the task.........davedotco said:The truly crazy thing is that most of the people I see and hear extolling the virtues of vinyl have pretty poor players, often third rate or worse.
Electro said:This is true but unfortunately at my age I struggle to hear anything above 14KHZ even on a good day . 🙂
David@FrankHarvey said:Thompsonuxb said:Lol...... I think thats the reason for alot of the disagreement on this forum, some systems are just not up to the task.........davedotco said:The truly crazy thing is that most of the people I see and hear extolling the virtues of vinyl have pretty poor players, often third rate or worse.
There's a flip side to the statement in bold. There are many that will be pro digital that have or have only heard or owned budget analogue sources. A turntable's quality is purely down to its fine engineering, and the higher the budget, the more accurate it will be. There are plenty who speak of turntables negatively that have only heard budget models but are comparing to highly priced digital sources.
Agreed, a budget CD player can sound clean, and lack the 'noise' of an equivalently priced vinyl player, but which one would people choose? Those that choose academic usually choose it because they can't hear a pop or a crackle, whereas those who choose the vinyl do so because it sounds more like music, regardless of any shortcomings, if any.davedotco said:A decent digital source is available at a pretty low cost so people, quite reasonably, see no reason to pay more. Some enthusiasts know enough about the whole 'computer audio' situation to extract very high quality sound at modest cost.
This is very true and matter of fact and I agree totally but why do I find myself trying to find music I want on vinyl first? I have a reasonable Turntable with a nice cart/phono and to me in my environment is the best way for me to listen to muisc. Yes I do occasinally listen to my DAC for convenience but listening to vinyl is much more involving and sounds fantatsic.Agreed, a budget CD player can sound clean, and lack the 'noise' of an equivalently priced vinyl player, but which one would people choose? Those that choose academic usually choose it because they can't hear a pop or a crackle, whereas those who choose the vinyl do so because it sounds more like music, regardless of any shortcomings, if any.
davedotco said:But hear is the rub, the big thing that you are rarely told, a better digital playback system does not, in the main, increase your appreciation of the music. Sure, if you analyse it certain aspects of the sound is improved, better definition, more separation etc, etc, but does it get you closer too the music? Mostly no, it does not.
davedotco said:Thompsonuxb said:davedotco said:CnoEvil said:marou said:No offence taken - I don't really have a view, having never compared vinyl and digital under test conditions. What does interest me is the number of people (including friends whose views I'm reluctant to dismiss) who prefer vinyl to digital despite evidence to the contrary which I find quite persuasive. Paul McGowan is a hifi designer and enthusiast whose views should not be easily discounted. So tell me, why does a legacy device with an inferior dynamic range which with every play corrupts the vinyl on which it depends still command the loyalty of so many?
Edit for spelling.
Er no it isn't.
It is pretty easy to tell if someone has any idea what they are talking about, and in this case you have not got a clue.
High end turntables with quality vinyl can sound quite fabulous, sadly there are so few in use now that most people never get to hear them.
Players that are capable of such quality are rare and expensive, especially these days, so few people have experienced the way that a fine player deals with background noise and the other 'limitations' that are handled so poorly on lesser players.
David@FrankHarvey said:I think many would be surprised at the lack of background noise on decks like the Rega RP3 and RP6 - great sounding decks, and not stupidly expensive either.
davedotco said:If you find that surprising you should actually hear what a player like an SME20A/Red Signature/Arc Phono 2 does with surface noise.
I know real hi-end players are stupidly expensive and 'elitist' but until you have spent some time with one, you really have no idea what good vinyl sounds like, and trust me, it does not sound anything like what you think it does.
davedotco said:But here is the rub, the big thing that you are rarely told, a better digital playback system does not, in the main, increase your appreciation of the music. Sure, if you analyse it certain aspects of the sound is improved, better definition, more separation etc, etc, but does it get you closer too the music? Mostly no, it does not.
This is most definitely not the case with vinyl, a better player simply gets you closer to the music, I'm not talking about the budget and mid priced players that dominate on this forum but really good players, the ones that reduce noise to irrelevance, produce all the detail, clarity and dynamic range of the best digital playback then produce the performance in a musically coherent and meaningful manner that digital playback can still not match.
