Vertical lines
alpne1
17
Hi I have a Samsung 51" plasma TV in the living room that has developed three pink/white lines top to bottom in the same place on the TV. I thought it might be Sky but after disconecting it and playing a DVD the lines are still there. TV is less than a year old bought from Currys. Any ideas. Thanks in advance
The_Lhc
1,176
chebby said:
alpne1 said:
:wall: :wall: Checked the warranty |( out by one month.
You only had a one year warranty on a 50" Plasma ? That's odd.
Anyway, still ask for them to deal with the fault. Also email (& phone) the manufacturer.
Yes, you're well within your statutory rights to have the issue dealt with, 13 months for (presumably) quite expensive plasma TV isn't a reasonable or acceptable lifespan.
