Anyone use any of the cleareraudio speaker cables?
Or the power hub and leads?
I can appreciate that sheilding will make a difference (especially as the cable to my left speaker needs to pass a 6 way power block and leads), but does it really matter, that much, if the cable is copper or silver? I know that silver is a slightly better conductor and also has slightly less resistance, but is that really enough to make a "double the cost" difference (at least in sound anyway)? As the terminals on the amp and speakers and the connections on the cables would be gold, which i appreciate doesn't tarnish but is a much worse electric conductor than either copper or silver.
I'm also thinking, would the gain in sound be better if i were to for example get the copper line speaker cable, power hub and 2 power leads (one for cd and amp) + the extra one cos the hub doesn't come with one.
Or would it be worth while to go for the silver line stuff, but not all in one go.
On a different note.. anyone use any isolation feet for the cd player? Did it make a difference?
Thanks for any advice,
Dan.
Dan.
