Hi
today i tried to switch on my sky + but it would not switch on from the remote or from the button on the box, disconnected power supply then switched back on everything seemed ok untill id tried to record a programme, when i pressed to record button it give you error message and code 06-0,also the system will switch off the on/off button stays green, the rest of the system seem to work fine. i have called sky they tried system reload but to no avail, then usual comment we can sent engineer but would be cheeper to upgrade.
wondered if anyone has come across the same problem
Thanks Andy
Thanks Andy
