acalex said:
Would be glad to try things. For now I am trying Lavardin cable...can also try Siltech and Shunyata which are in stock at Francis'. If I can get speaker cables with the option of sending it back I will be glad to do it!
Right, I've spoken with Gary at Kronos about Vertere, and the position is that they would be delighted to deal with you,
but would need permission from Vertere (via email), as they would be going outside their area.
He said it should be as simple as contacting Vertere, and finding out if they are happy for this to happen, as it's possible they will either deal with you direct, or have a distributor that has been lined up.
I would put that:
1. You want to try their cables as a result of reading the write-up of the musical evening at Kronos on here.
2. You would like to deal with Kronos, as they come highly recommended and (if) you've used them before.
3. There are other possible customers in Brussels who are also interested (ie. Brussels Massive)
If it worked out, they would send you their demo S/Cs (probabaly 3m) / 1.2m I/C, and if you liked them, would then send you new ones. You would probably be responsible for postage....but you could negotiate in your usual way.
He said the standard smallest size of S/C is 2M, and that 1.5m would be as expensive, as they would be bespoke.
Apparantly the most popular size of I/C is the 0.65m.
I suspect you would need to be looking at the
Pulse B for the I/C.....if 0.65 is too short,
you add £160 for the 1.2m (if I picked him up right).
And
Pulse X for the S/C.
This is not as "official" as it sounds....Kronos, just need to get the nod before going ahead. If Vertere have nobody appointed in your area, I can see no reason why this wouldn't happen, especially if you give your preference in dealing with a known and recommended dealer.
Let me know how this plays out.
Cno
