There's no point performance wise, and should your cable cause a fire.......
I have them tested after I have made them.There's no point performance wise, and should your cable cause a fire.......
HDMI was most noticeable for me.
Just so I understand, are you saying that you use freebies or that you only use freebies?
Please also put me down for 2.
I'm puzzled by @M42TYN statement about replacing an HDMI cable. Unless a cable was faulty I have never experienced any difference between HDMI cables.
I read this years ago and I think they're right: https://www.cnet.com/news/why-all-hdmi-cables-are-the-same/
With RCA interconnects I do believe quality matters a bit. Same goes for coax cables for the TV. Better shielding of the cables and connectors makes a difference.
may i ask have you ever used more expensive interconnects (make / model) and if yes what results did you obtain ?
Most speaker manufacturers use any old cable inside their speakers so using ultra expensive speaker cable seems a bit pointless. The analogy is hi-speed broadband. You have a super duper fibre cable going to that green box near the village green but then it's cheap copper cable from there to your door, and you wonder why you're not getting the benefit of that massive speed increase.......
I used a Van der Valk (something like that) on my turntable and it hummed. Freebie red and whites, no hum.
Musicraft (Rick) is well known not to use any exotic cables as far as I'm aware.
Let's face it if an interconnect comes with a component then the manufacturer must think that it's suitable for use with that component. Exotic cables might look pretty but you'd need one hell of a system to spot any SQ differences, if any at all. I'm damned sure that if any difference is noted then you need to look inside your head for answers.
PMC state that speaker cable of a suitable gauge is enough to drive their speakers, and Harbeth use Van Damme cables in their speakers.
It used to be Chord - I had some bass issues years ago using Van den Hul speaker cable and a switch did as MA said it would.replacing the wires found in budget speakers is, i have been told, a worthwhile upgrade. its also one of the features in monitor audio speakers the use of van den hul cabling internally.
It was Chord Odyssey 4 in the GR20s, but that's quite a long time ago. I keep wondering about changing them, but it's difficult to audition, it'd have to be a worthwhile gain, and they keep showing how good they are in responding to upgrades. Time to stay as I am, at least for now, I think...
Yes.russ andrews i believe sells cable / wire(s) for you to specifically replace and upgrade the ones found in speakers and amplifiers. he even produced a guide on how to do this years ago as i have a copy.
(the guide was free and ultimately you dont have to use / purchase his products so its was an interesting read all the same).
is this all nonsense ?
so you agree different cables (designs) do / can make a difference ?!
Not sure I dare report that I've added more weight to the CD!so basically you matched your speaker cable to the cable present internally in your speakers - synergy !
i would keep your speakers if happy with your system - a lot of sideways steps in this hifi game...
you seem to be open minded enough to experiment with tweaks (lead weights etc) so i would explore more of those as they often are a lot cheaper than full scale hardware changes !
Yep. Poorly made cables can cause problems. Stick to the old red and whites and you can't go wrong. 😛
