Throwing the cable cat amongst the pigeons!
Even 20 gauge is good for >20 foot into an 8 ohm load.
I have some quite expensive speaker cable here, which I purchased many moons ago, when I was, shall we say, more easily convinced. I do still use it, but I performed sweep tests on different speakers using different cables, and it turned out it was no better than a length of flex, cut from an old electric lawnmower.
My sister loves music and I was rigging up my old system at my hers a few years ago, she wanted the thinnest wire possible, she's houseproud so didn't want ugly cables. I bought some single core bell wire from Wickes in an attempt to deliver her wishes... it was useless, no bass whatsoever. Wickes also did white speaker cable so this is what was used. I have no idea what the wire gauges were but the bell wire in this instance was utterly useless.
It's so peaceful. Impressed! Are we talking about analogue or digital cables?
It's more peaceful than I was expecting! I was talking about analogue, though I do have a digital example at the risk of starting derision - it's the only one I have ever noticed. I installed a 'better' HDMI lead (nothing too posh - just in the £30-40 bracket) and Mrs 12th and I watched Pan's Labyrinth on blu ray as a comparison. It was readily apparent that the crackling of the fire in the Pale Man scene was clearer and crisper - Mrs 12th remarked on it unprompted.
My previous CDP had two sets of phono outputs - for a laugh I tried connecting it to amp by both and toggling back and forth between a freebie and the interconnect I still use. The bass did a disappearing trick then too - repeated when I swapped cables so there could be no other cause.
may i ask what make / model was your previous cd player ?
seems an excellent way to instantly test different interconnects !
An Arcam CD23t - I did it with the Chord interconnects suggested to go with my speaker cable, but couldn't tell the difference between them and the VdH in any respect. Reverse was true of the VdH speaker cable I had which did its best to make every bass note sound the same - guy from MA recommended the Chord cable as that's what they were using for the internal wiring and the effect was, to put it mildly, transformative.
Please also put me down for 2.
I'm puzzled by @M42TYN statement about replacing an HDMI cable. Unless a cable was faulty I have never experienced any difference between HDMI cables.
I read this years ago and I think they're right: https://www.cnet.com/news/why-all-hdmi-cables-are-the-same/
With RCA interconnects I do believe quality matters a bit. Same goes for coax cables for the TV. Better shielding of the cables and connectors makes a difference.
Reactions: Wolf
Overwhelmingly number 2, it seems.
Fair enough.
Wonder how many of these are shifted?
years ago i received some literature that stated something like 40 or 50 thousand of his powerkords had been sold.
to be fair to russ andrews though he only sells, does not make, kimber kable and the prices of the top nordost cables make the russ andrews badged powerkords seem like pocket money !
Nothing whatsoever to do with cables, but when auditioning speakers, if you set 5 pairs up to try out, yes they probably do all sound very different, but who, apart from the listener, is to say which is the best sound?
You wouldn't really be aware what the sound the recording engineer had in mind.
However, as I'm old, and been to too many music venues, I don't think my ears work too well any more 😫, so a moot point...
How can it be proven that all HDMI cables are the same but RCA cables can be different?
I wouldn't necessarily agree that the article constitutes proof but the aim of the thread was just to establish what people thought, rather than start an argument about it (there seem to have been enough of those in the past).
Does that mean you are a '1'?
It was a genuine question; doesn’t make it an argument. I have an open mind. I struggle to see how what is essentially wire - as long as it is correctly insulated with well-made connections/plugs - can have on sound quality. If somebody can provide empirical proof it does then I’ll subscribe.
However, I do believe people can spend their money on what they like. If they can hear, or believe they can hear, a difference then that’s all that matters.
The other thing I believe as that as long as there is hifi, there will be debates about cables. Life’s too short. Go with what makes you happy. 👍
The question is far too ambiguous, and if we are talking about all cables, then there are far too few poll options (there is an option to add a poll when you start a thread). You need to specify whether it's speaker cables, interconnects or digital cables we're discussing, and whether it's coax, etc. The ambiguity doesn't allow for a number 1 answer, but maybe that was deliberate.
So you keep saying, though no-one else seems to object to how the options have been framed. Feel free to start your own if you feel it's needed, but too many options limits the response you tend to get.
dont forget mains cables !
I suspect it's more that you didn't like the answers, Mike. Plenty of people answered, not 'no-one'. But revert to sneer and the need to be right. Weren't bullied at school, were you? 😉
How could I possibly not like the answers, when most people gave the same answer I gave? 🙄
And "bullied at school"? Really?
does mcru or russ andrews sell them ?!
Most likely.
