Al ears
I intend to, hopefully you can to.Thank you for taking so much time to reply to my questions I really do appreciate it . Enjoy the rest of your evening
Nope. I had the 2M Red. Couldn't get on with it.Don't go there.... 🙂
Thanks for that much appreciated.Nope. I had the 2M Red. Couldn't get on with it.
My ClearAudio is much better. I know many in the know suggest ClearAudio is AT in a different frock. I can tell you now they sound very different.
Glad I am not the only one.... 🙂Nope. I had the 2M Red. Couldn't get on with it.
I hope you two are not trying to steal our thread 😉Glad I am not the only one.... 🙂
for what it's worth, and it isn't cheap, I am led to believe that replacing the turntable mat with a Thorens leather one can lead to noticeable improvements and might move worth looking into in future if funds allow.Cleaned up the platter today ( I know that it won't stay that way ) the AT-VM95 cartridge is ordered arriving tomorrow. I am away till Friday then I will be fixing the cartridge to the arm / wand and finishing the set up ready to start using it.
I have a non static mat that I bought for the original deck which I will be putting onfor what it's worth, and it isn't cheap, I am led to believe that replacing the turntable mat with a Thorens leather one can lead to noticeable improvements and might move worth looking into in future if funds allow.
Hope you enjoy the AT
Not at all. Just trying to be honest.I hope you two are not trying to steal our thread 😉
Well you must have read the 2m was shot out of the running and I listened the advise given and bought the AT instead. Thats what the forum is for advise for those that need it.Not at all. Just trying to be honest.
Nice.Today I have managed to fit hinges to my Place on dust cover for my Thorens TD 147.
It is much better than having to remove the cover every time I play a record.
View attachment 3423View attachment 3424View attachment 3425
All ready now for a set of really expensive RCA cables 😉Nice.
You had to go easy drilling into the nice wood.
This is my 160S. Just had to hack the baseboard to fit the RCA sockets.
(Mains and signal cables were a bit too close together in the original exit point, so I put a bit of distance between them at the same time).
....there was that thread from someone that only got rid of hum after changing from very expensive to very cheap cable - the basic evidently had better RFI immunity 🤔All ready now for a set of really expensive RCA cables 😉
