New Turntable suggestions please!
Designer left roksan years ago TMS ( Touraj Moghaddam ) and started Vertere
MAudio want to do digital only these days , Turntables are very hard to design and need decades of knowledge & anyone going head to head with Technics , Project & Rega is either a talented genius or a pure nutter
I'd read that as talented genius if his Vertere turntables, phono stages et al are anything to go by.....
There are plenty of turntable designer out they whose decks knocks the socks of the major players but turnover means they are going to cost more.
That's one, however they do appear rather reticent to publish prices online.
I think it's because he doesn't make them in bulk and people around the world ship their turntables to him to modify. I have met him and he is a fantastic person and has always got time to chat. I bought my turntable second hand from eBay I got in touch with him and asked if he would give it a once over he took 2 hours of his time to set it up and chat and he only charged me £25. Obviously I haven't touched it since.
The TTV2 arrived this afternoon. I have bought a few factory refurbished items in the past from various companies (more often than not Dyson!) and they have usually turned up pristine/as new. The TTV2 is no exception. Well done Cambridge Audio....
Anyway, unlike the Attessa, I had it up and running in less than 15 minutes out of the box. Such a simple setup.
Initial impressions after spinning a few records.
Easy to use. Great sound quality - I could hear so much more detail than I could with the Attessa (when it did work) and it is leaps and bounds ahead of the Project Debut.
Only strange thing is the output from the built in phono is not as loud as other Hifi items I own. Probably 20% down in volume on my other items.
My PMC 20/24's do I believe also need a powerful amp - probably more powerful than my Roksan Oxygene amp. I usually listen through other sources at a volume level of 60 (assuming out of 100) which is quite loud. The TTV2 Turntable through it's built in phono needs to be at 80 to match the sound volume of other sources (including other amps).
I think it may be just a case of my Roksan Amp not being powerful enough. It probably doesn't really matter as I seldom turn teh volume up any higher on my amp.
Tomorrow night I will give it a good test with some of favourite pieces of music. Some purchased in the early 80s and some bought recently.
I'll also have a play with the bluetooth and my Sony headphones.
Only thing that I need to sort out is the Attessa. In a box with a broken stylus and a £150 cost to replace. I did speak to Roksan and they did say that I could return the turntable for a health check. It will fail of course fail the tests if the needle is broken.......
So all I can say is thanks for the help and assistance. I'm amazed how good the TTv2 sounds!
Whilst we're here, I would perhaps advocate against the Cambridge TT V1 model that preceded the TT V2.
Main reasons being I think there were issues not being able to switch off the Bluetooth or phono stage outs options, which is a pretty big deal from a user perspective. The V2 model is unaffected by this and likewise the Alva ST both of which allow you to bypass the Bluetooth and add a phono stage of your own choosing.
Just one point - it’s probably not power that the amp lacks, but gain. They aren’t quite the same, and it’s too late to try to explain the difference now. But turning it up as you have is fine, unless you’re getting lots of background noise, which is unlikely.
Agreed, it sounds fine and isn't running hot at all so I have worries.
I suppose part of the misconception I have in my head is that when I had older systems in the past (Arcam Delta 90, Audiolab power amp, Mission 751's etc) the volume on the amps were only set to 3 and the windows rattled.
Anyway the turntable is great. Only thing that hasn't been sorted yet are my Sony WH1000XM4 headphones through the Bluetooth connection on my turntable. They work but a little too quiet for my liking, even on full volume.......So back to the drawing board on that
Time to enjoy the turntable for a bit. Then figure out what to do with the Attessa Turntable. Try and find a copy stylus to at least get it working that doesn't cost £150. Thta may be next year's problem though.....
Reactions: nopiano
I notice Cambridge state that the v2 has a "high-output Moving Coil" which would take the output level down: I have similar (the Hana SH Mk2) and they tend to whip up only 2mV or so, compared to 4mV to 5mV for a MM. So I have to turn my amp up when I put a record on, too. Your comment is consistent with Cambridge having put a MM phono stage in and fitted the HOMC. This is understandable as users considering a change or upgrade would probably be looking at a MM for a turntable at this price point.
Reactions: Pete Shields
Still loving the Cambridge Audio turntable and spinning all sorts of recently purchased as well as some of my 45 year old plus stuff. All sound great.
Paid a visit to Richer Sounds in the week regarding the Attessa. They couldn't unfortunately help source a replacement stylus and could only suggest that I install a cheaper alternative cartridge/stylus then sell on. Probably my best option, although the guy in the shop did say that the turntable was very marmite with their customers. Some thought it was great and others could not live with it. I'm in that second boat....
I spoke to somebody on the Roksan chat and they provided the option of returning the turntable for a checkup. Not much point in my books if the needle is broken and they probably won't do anything with it because of this
So a sale on EBay is probably my only option. I either sell it saying it needs a new stylus (and the positive that the turntable itself still has 3 or 4 years warranty left on it) or I buy a cheap cartridge/Stylus (any suggestions that would help would be greatly appreciated) before I move it on.......
I would suggest buying a Goldring E3 cartridge and fitting that and so sell it as a going concern.
No doubt if it had to be a pro-ject turntable, this would be it and the cartridge if better than the red is already something ,
never heard the silver but i put my faith in others knowledge as i have a 2 M black and not that good, only extremely filled with high´s , no detail , put on it a 207C cartridge built by Nagaoka to Technics, who were nothing special, but today are amazing. in 83 Technics had their stylus built by AT , i even have a tonearm from AT on a PLC-590 or in the U.S. PL-C 590 from Pioneer 20 series, 70´s product
i can give the example of the cartridge above the cheapest one of AT in 1983 and bought a Huco swiss brand of substitution stylus , the cheapest AT stylus ,sold it . A Pioneer turntable of 83 bellow the top model, and it was not comparable of so good it was to the 2 M black but also heard that some prefer the bronze who in my opinion bellow the cadenza series is not worth buying any,
compared to this new expensive vinyl readers with new built cheap cartridges and stylus very weak and a lot less hours of use,and asked fortunes for one aceptable cartridge
that nothing resembles what we 70´s generation heard with a very high quality, what still are sold but now vinyl instead of records.
Also a friend , a deutsch one, having every good turntable known to men ,he bought some years ago a Pro-Ject turntable that sounded like a good old one ,
and he did it like a dare and i was surprised it even looked like one ,
only too ,well not going to compare it with nothing but with his built tube amplifier from early 70´s and still using the B&W 801 ,i think he told me he had bought them in 1979,
spent in total 14.000€ the top Pro-Ject turntable, including a hana cartridge,
only after all , he put it again in the box and kept using his signature rotor turntable that sounds amazing and he has not a cover on the turntable but after listening to records he covers it with a crystal clear box that covers it all, also has the biggest collection of cartridges and needles for them by the side , since late 60´s he told me,
and he has a lot of turntables ,cartridges , amplifiers and speakers ,once he was using a Luxman from late 70´s with a control amp also luxman 45 watts he says but the sound it´s clean and loud with some not that big Altec lansing , also other time i saw him using a Accuphase two mono blocks M-60(tube ones) if memory doesn´t fail me he had a C-200 as control amplifier this using some mid 70´s JBL ,
old but almost perfect, this was my type of sound, also have a E-303X from the 80´s and a DP-60 cd player ,90´s one and not that long ago bought DAC , a DC-901 because it is a accuphase, normally i install a new internal dac, if the cd player as one not that good,
i´ve been hearing carefully cd and record version of the same album of diferent styles and noticed in good sounding cds that no vibrations are heard in the instruments played like saxofone or similar instruments with big variartions ,
also electric guitars as the strings produce a vibration cutted and the sound of the guitar is putted very low compared to the original record, more or less instruments sound like played in a good modern synthesizer,
sometimes i go to his home in the countryside and he puts records to play ,in direct but we hear all sounds with good level coming from the 801 from B&W. he also has a litle agriculture indoors and basically white widows his it biggest production,
He his maybe the only person who says he is a Audiophile and i agree. he is 92 years old now, just love his buddy rich big bands records some or most are recorded live, his entirelly dedicated to hi-fi components , changing each year all in his 70´s Range Rover, that uses a V8 gasoline engine,
also a litle agriculture with very sensible species ,with a hidroponic system and a huge amount of electricity spent every month, that he produces by a filled with panels part of his property, he says the electric company each month gives him money,
He installed alone a new turntable from goldnote and he calibrated all by hand and hear, this friend of mine that we met when we were 4 years old , was amazed because after he had all gadjets and checked , he couldn´t believe all was literally perfect aligned.
I only wrote this as there more to it than just put the same value of weight in the stylus in the anti-skating either than perfectly flat in a table with wooden IKEA boards, the smartest way and it works. Sorry for my XXL reply.
Have to say that now i understand better when they say cds sound better than vinyl has i went to a young man´s house where he showed me a complete system he paid 5.000€ for all and well assembled, all for vinyl reading from power suply´s to cables, power amp, speakers from Canton but looked good with stands, Naim was the amp. and a very nice looking turntable and he already has 27 vinyl records and 36 cds but the cd player is not in the system i heard,
well times are changing and maybe i´ll be gone and the peak and evolution of all that allows us to have better and better equipment well installed it will be like listening to a 60´s pocket A.M. radio,
but i´ll be gone and my great great sons will say "the old fart who does he thought he was , one listens to his system and instead of hearing a SACD MK XX we hear a band playing around us like in a big concert hall, that´s not Hi-Fi "
"Thick wood and aluminium like we never had seen, that resonates a lot, thin plastic that with the years will look like 80´s vintage plastic no wonder is generation wasted all Earth resources"
What happened to the flying fish that would fly above the boats deck, if it hitted a persons head could cause injuries, once i travelled from Portugal to Africa, still young with my mother in a big luxury ship in 1973 and saw many, and later in my highschool the science room had one but preserved , No one talks about it, it seems the same is happening with High-Fidelity,
Some kids buy only 70´s stuff and ask me "what is the R.I.A.A. curve?" or "what does that sticker means , DIN 45 500?"
I understood the first paragraph. It all went downhill after that…! 🙁
If Pete still has the Atessa deck and hasn't shifted it yet, totally get where Al ears is at with the low cost but good cartridge is at, however if you want to shift the thing as a bit of stock you don't need and given you can buy an Atessa for under £400, instead of blowing £100 on an E3, get an Audio Technica AT-VM95C at £35 and minimise your losses. When you post the ad on Ebay or wherever, you can justifiably post it comes with an excellent cartridge too.
