Question Pro-ject Debut Carbon skipping
Rikcougar
Good afternoon all
I have a Pro-ject Debut carbon which I run through my Sonos system
It seems to skip every 5 seconds or so
I have set the tracking force to the correct 1.8 g using a measure it and the bias is on the second slot
Turntable is not quite level but pretty close, catridger is original 2M red and turntable is around 10 years old
It has not has a lot of use in that time
Any thoughts on what will fix it greatfully received
I also have an AT LP120XBT-USB which has the same problem, I guess it must be a Sonos thing
Odd that it skips with such regularity, check weight with a proper set of scales, set anti skate to zero and check condition of the cartridge itself.
Is it the turntables issue or the fact Sonus cannot accept input. Don't know hor you connect a turntable to a Sonus output mind you.....
Doesn't it need a preamp?
Some years ago ,maybe 2020 i was ofered a new Pro-Ject turntable the evo carbon or similar ,it came with the 2mred cartridge,
i think before, this model was sold with a OM cartridge also Ortofon, i assembled it, put it working as acurate as i could ,having diferent measure devices ,from weight to anti-skating and leveled in a very acurate way ,
at the time i was using a old but kept in the box SL-3310 with a 207 C cartridge and still had a old stylus as they were built `till the 90´s,
having this new turntable and still thinking Ortofon cartridges were good as it were before , that none sounded bad,
i only knew this brand when very young my father bought a entire B series from Revox that being a litle diferent from others , tangential with the box turned over the record, in 77 all inside was branded Ortofon and the sound was close to perfection,
i even thought that after seeing a turntable from technics ,also tangential and other from Pioneer , that tonearrms would disapear but it never happened, as it was seen in early 80´s,
only later ,maybe mid 80´s i had acess to a early 70´s technics ,that using a shure cartridge it sounded very good and acurate , a SL-110,
since then i´ve bought two other turntables and in the 90´s or 96 i bought for my new system a thorens TD2001 but after some good years ,all had problems and the 70´s turntables kept working perfect, the main reason i in 2017 started using the SL-3310.
All of this to say that when assembling the Pro-Ject turntable ,it all loocked very frail and the arm anti-skating wasn´t built strong but all looked very cheap,
and soundwise was very bad , and that´s when i discovered why all talked about using pre-amplifiers,
as the sound coming from the turntable with the inpedance correctelly selected in the amplifier i was using, in the past depending on the cartridge turntables had diferent volume in output sound ,
but also there was already a lilte volume knob in the amplifier for the phono input, this in a 70´s Pioneer but also in a 80´s Grundig, after all i asked the friend who had ofered me it if he wouldn´t keep it as he had stoped a 77, SL-3100, that was as new,
he after hearing the pro-ject in my system , said he wouldn´t mind keeping the pro-ject and giving me instead the technics that he wasn´t thinking of ever putting it to use and so i trade it,
again a 70´s turntable without auto-return and very simple but a perfectelly made mechanical system like in the SL-3310, as it drops the needle very smoth in the record as after in said to be better turntables it dropped not to hard but a litle more high drop of the needle,
like in most of the 79 , technics models, that some say they are better , only never understood why, except my father´s SL-1000 mk II, that basically is a SP-10 mk II with all parts sold by technics and was expensive and works perfect today, even the MC cartridge sold by technics had a pre-amplifier fot it, but conectable to the phono line,
My opinion is that all this new turntables will not last a lot of years and i´m using turntables with more than 50 years with acurate sound and good quality wise
If only you’d read post #6 we would have been spared your life story! It was nothing to do with the turntables!
