The Latest Purchase - Onkyo TX-NR818
Page 8 - Seeking answers? Join the What HiFi community: the world's leading independent guide to buying and owning hi-fi and home entertainment products.
John Duncan said:
Overdose said:
provided it can properly control the speakers attached to it and not add any audible distortion
Shall I help you out here? The £1k Onkyo receiver quotes 0.8% distortion, the £1k stereo amp quotes 0.08%. I am going to presume that since they come from the same manufacturer, they're using the same sort of measuring tools.
Have you compared the 2 amps JD? Do you know if that level of distortion is audible?
the record spot said:
Renman911 said:
I wonder why the OP thinks it sounds better than the stereo amplifier then? It shouldn't.
Probably because I've worked my way through several of the former, have an open mind, and think that it sounds as good as any stereo amp I've owned. Have you heard it or just quoting perceived "wisdom"?
Sorry I was under the impression that it's distortion levels were higher at the time of posting that comment. If they're the same then I assume it could sound just as good.
I didn't think one needed to listen to things and that measurements were sufficient? Or is there benign distortion now? What level of distortion would be audible?
I agree that it's useful to know what the measurements are, but they only tell part of the story. The other bit being actually hearing the thing. So having done that... 🙂
Not wanting to be pernickety, but aren't your only points of reference, re amplifiers, only the ones that you've used with your current speakers?
If you're also factoring into the equation how other amps sounded with different speakers, you're comparing other speakers really, no?
I'll help you out John.
Depending on where in the frequency spectrum the distortion is, it can be 20% or more, above 8KHz it's 1% and over.
So in all likelyhood any distortion below 1% at just about at any frequency will not be audible.
@Renman - Not quite. In my current setup at home I can swap out an HK6850 (95wpc), Sony TA-F630ESD (circa 90wpc), an Onkyo TX8050, and there have been a few others in the past. So yes, I can claim to a few with this pair of speakers. The tonality of the 818 suits my ears nicely and brings out the characteristics I look for. It's quite similar in some ways to the HK990 from memory; pretty neutral, but very fluid at the same time. Works well so far, much like Andrew E has reported.
Overdose said:
John Duncan said:
I picked the 828 and the...9050 off the top of my head, because they were close in price. THD+N was ten times that of the stereo amp. But at least I looked...
But you didn't understand.....
That'll be why some manufacturers don't quote measurements then, in case we don't understand?
Thanks, but AVI aren't really my kind of company. The Onkyo does drive the Tannoys well but it's time for some of these other amps to go. When I get the time they'll be on Ebay...!
Where did the AVI reference come from? The post above?
Correct. Max just couldn't help himself.
Not wanting to join the fight, but I'd be interested in the source of these numbers.
Matt
Matt
A quick bit of googlage should see you right.
The only figure I saw for the Onkyo was 0.08% but it depends how you measure it, Ive seen 1% for the Kandy K2 but that was at max volume.
No expert on soundtracks but some I have heard like Blawk Hawk Down sound fine on my system, in fact better than many recent music albums.
