Budget amplifier for parties
smallzoo
22
Hi
I was looking for a simple budget ( ideally bluetooth ) amplifier so my daughter can play her iphone at parties
My speakers are I guess vintage now Tannoy Mercury which I love..so I tried connecting an AK45 amp from amazon
The amp seems pretty good for only £35 BUT a full volume it doesnt seem that loud.... or am I wrong
Based on the specs of the speaker and amp what am I doing wrong.. if anything
Tannoy
AK 45
this is what it said ?
  • 300W x 2 Power Output: The Romicta AK45 audio amplifier is completely redesigned to deliver a maximum output of 300W per channel (with 40W per channel as continuous power), perfectly suited for driving passive speakers from 4″ to 16″. Its compact build makes it perfect for home cinema, karaoke and multimedia sound systems, fitting seamlessly on any shelf or A/V unit.
Amps like that are a waste of time and money. Have you had less that 14 days? Inform Amazon you intend to return it. They are obligated to refund you.
Those aspects look like Mercury Mk2, they are nice speakers and deserve a better amp. I would look on ebay for a Marantz (plenty of other brands, but I like Marantz) from the 90s or 2000s. Expect to pay anything from £50 upwards, normally around £100, but with patience you can always find a bargain.
You will then need to add a Bluetooth receiver, you can get one for £10 to £20 on Amazon. However, I would take a look at the SMSL PS100. It is a DAC and Bluetooth receiver for £27. It's in a cheap plastic case unlike the sturdy aluminium of the SU-1, and the DAC isn't as good, but it's very good for the price. And adding a DAC to an old amp can always come in handy.
In time you may want to add a streamer. For £80 the WiiM Mini is a considerable step up from Bluetooth.
Thanks for that, sounds a good idea but I don't have the time as she has a big party in only two weeks.
I will start looking though
Forgot also to mention..the reason for the panic as I was going to use my faithful rotel amp but it stopped working and I cannot find anyone to fix it quickly 17624.jpg
It has power for a low price for a new amp
Are you saying at £75 from Amazon the fosi is a good loud amp ?
I have never used one, but am told they are good. one thing to look out for, they come with either a 32V/5A or a 48V/5A power supply. All the specs are based on the with the 48V/5A option that is needed for maximum power output.
It also doesn't have Bluetooth, so you will need a Bluetooth receiver, or connect by cable.
So do you think connecting a phone to it will be a lot louder than the AK45 I bought ?
Obviously people are going have lots of different views which is to be expected as everyone has a different ear 🙂
All I want is a decent amp that I can use with a phone ( I would by a bluetooth adapter separately if necessary ) and that is a lot louder than the cheap AK45 I just bought...and under £100
Yes, the Fosi will do the job. I would certainly recommend going for the higher voltage power supply option.
Then for well under £100, have a look at the Lepy 2020A - better than the price would have you believe.
(I put one on each of my biwirable speakers, but one will be all you need):
...and those of us that have tried the Fosi V3 can confirm that it's great - and should be more than loud enough for your daughter's party (if you want to spend more).
Meantime, if you haven't already, maybe get the lid off your Rotel....
thanks for that
thought about the rotel but electronics are way out of my sphere
