Subwoofer (for the organ) on an ultra-budget system?
Not arguing with that, I am talking of 2 of the same subwoofers will only give +3db due to increased come area, amplification remains the same.
Bill
You say you're not arguing with that... and then you do. Which is it? When you double the number of powered subwoofers, you are doubling the amplification. If you double the drivers without doubling the system wattage, you are dividing the wattage between the additional units, which is why you only yield the extra 3dB through additional cone area and acoustic coupling. When you double the number of powered subwoofers, you are doubling the cone area and system wattage, yielding +6dB.
Matching subwoofers, both are 150w and with the same input produce 86db individually, play them both together and the only thing that has changed is the doubling of the surface area, hence the 3db increase.
You have a 7 channel Receiver that that puts out 50w per channel, which means a total of 350w, however the sound produced by the speakers is still only 50w each as they are individual with their own dedicated channel . (Just because you have more power doesn't mean more volume unless you increase the power on the channel)
If you connect to drivers to 1 amp then you should also get 3db (In reality it is less due to the way the drivers interact to each other), now if you double the output of the amp as well then you will get a theoretical 6db increase in output (Due to losses and interaction it will always be less)
To put it simply, adding an extra separate amp to drive another speaker, does not give you double the power output. (That's not how amplification works)
Bill
Bill
Your analogy doesn't work at all. Subwoofer signals are almost always mono in nature, even in stereo sub situations, as low bass is almost always mixed down to mono, whereas in an AVR, you have wildly different signals going to each individual bed channel. But even then, quarter wave and constructive interactions occur, which is why the center channel signal is rerouted into FL/FR at an individually lower output so the center channel information doesn't overwhelm the front stage.
Let's take a single driver subwoofer with a 1000W amplifier. Let's say it has a max output of 100dB.
Scenario A) If we simply double the amplifier power to 2000W, we are now increasing the amplitude by 3dB for 103dB. Same concept as needing double the power for a loudspeaker with 85dB sensitivity to produce the same SPL as an otherwise identical speaker with 88dB sensitivity.
Scenario B) If instead we redesign the subwoofer to hold two drivers with equal performance, but use the same amplifier, each driver can produce 100dB for the same system wattage (1000W total), even though the wattage to each driver has been halved (500W each). The two drivers have acoustically coupled at frequencies with a wavelength greater than 4x the distance between the drivers, which is the quarter wave theory. This is gives us 100dB+100dB, for 103dB.
Scenario C) But let's spend a bit more money and buy two 1000W amplifiers to sit in our subwoofer instead, one serving each driver, receiving the same signal - along the lines of a PV1D or a KC92. We have double the system power AND double the cone area. We know that our individual drivers will output 100dB each when powered by 500W, so at 1000W, they would now each be producing 103dB. When the sound waves hit each other, through acoustic coupling the amplitudes add together, for 103dB+103dB=106dB. So +6dB from our now dual driver, dual amplifier subwoofer.
Now just put one of each amplifier and driver combo in their own boxes instead - two separate subwoofers. Signal path hasn't changed whatsoever, but we have doubled both cone area and system wattage. Both amplifiers and both drivers are still receiving what they receive when they are in one box, as per scenario C. The sound waves don't care. All they care about is that the sources are within a quarter wavelength of a given frequency, acoustically coupling, giving us +6dB for doubling cone area and doubling amplification.
This has been well understood by audio engineers and loudspeaker designers for a long, long time.
Reactions: nopiano and manicm
3db? 6db?? 🤷‍♂️ Glad my question gave people an opprtunity to disagree 😉
I am going to spend some time listening to organ music with just the speakers I have, no subwoofer, and see how it goes. They do sound pretty amazing by themselves, but let's see what Amazon's Black Friday deals bring, if anything!
Reactions: manicm
Hmmm, something else occurs to me (a bit late in the day!). Talking of church/pipe organ music here, people (including me) have been basing their stats on a real organ, situated in a church or concert hall. In that live environemnt, yes, the frequency may well go down to 14Hz or lower with larger instruments; but of course I am playing music from a CD, or via my HiFi Walker H2 (where files may be lossless, but may also be MP3s (albeit ripped at 'best quality'). I doubt whether any source material I possess gets anywhere near 20Hz - the lowest frequency a CD produces, AFAIK.
There's a very nice-looking KEF subwoofer, with frequency down to 10Hz, for instance: way beyond my budget, but even if I were ready to spend £3000+ on a subwoofer, what would be the point when the source would not have captured (or contain) frequencies anywhere near that low?
Or am I missing the point?
The stated frequency range of any subwoofer will usually be +/-3dB, sometimes +/-6dB. That means it's lowest stated frequency, in this case 10Hz, will either be half as quiet as the average of the rest of the range, or half again. Having a sub reach 10Hz will usually mean you've got decent output down to about 20Hz, roughly. It all depends how much usable output you want at the extremes. Digging deep and doing it with authority costs, and will usually cost big. And to do that with a small sub requires a lot of DSP, which will affect sound quality.
But reaching deep is just part of the story. Distortion will play a large role in most subs, and the deeper you get, the higher it will be, and when it gets too high, you'll be 'hearing' the sub and its location. With a clean sub, you won't.
Then there's that agile, punchy sound that many subs fall short on, as they're concentrating on trying to get as deep as possible. They focus so much on that they overlook or just cannot do well further up the frequency range where they need to blend with loudspeakers and sound like a natural extension of the loudspeaker.
surround sound does do that low im pretty shure
Thx or atmos music in stereo og some new format i don't know, should go low enough
I think there are alot of music that goes down to 20hz or lower or else they would make subs that goes down to under 20hz like kef kc sub and many elac subs + the high end stuff
Im shure most people don't need more then down to 20hz flat
Real to real ?
I still have the gut feeling that few, if any, of my source music files (great as they sound on my budget system - just to recap: HiFi Walker H2 player/Fosi SK01 preamp/Fosi v.1.0B amp/Micca MB42X G2 speakers) include audio data for that ultra-low range of the spectrum (c.15Hz-25Hz). Not to say that adding a subwoofer won't round out the overall sound and add some extra realism (especially low orchestral sounds and pipe organ - I pretty much only listen to 'classical' music these days), but I am looking at subs in the £200-£300 price range now (and waiting for Black Friday prices before deciding). A number of these advertise a frequency range down to 25Hz or thereabouts.. and I will in any case buy from Amazon, so easy returns (bless 'em) should I be disappointed.
down to 25hz not for £300 and for shure not at -3db
Mabye £500
Kali Audio WS-6.2
ADAM Audio T10S
Yamaha HS 8S (22hz but i think it's -20db)
As mention if they focus on extention there not lefet with £300 sub for making it play loud
You also need a sub you give the full siganal and out comes a high passed filterede signal for the amp so the small miccas don't play bass under 60hz or 80hz what ever you want
There are a small number of subwoofers on Amazon that claim to go down to 25Hz in that price bracket, but perhaps not at -3db. I have just made a shortlist so far; I would look into specs/details more thoroughly before buying any of them, of course.
I'll take a look at the ones you list as well (I already have the Yamaha HS 8S on my list. Not sure if the Kali subwoofer is sold on Amazon UK though).
These are the units I am keeping an eye on currently, on Amazon, waiting to see what happens for Black Friday. Maybe any folks reading this could say 'OK', or 'no way' if there are any they feel strongly about:
ADAM Audio T10S
Wharfedale Diamond SW150
Yamaha NSSW050
Yamaha NSSW200
Audioengine S8
SVS SB1000
SVS SB1000 Pro
SVS SB2000 Pro
I doubt the last-mentioned, at £1000, will end up in my living room, unfortunately, unless it is reduced by 50% or more (?!). (As I think I mentioned somewhere, I recently spent a five-figure sum on a three-manual (Johannus) church organ for my house, so I need to be 'sensible' for a while).
Thank you.
For £300 new you can't get that kind of bass and not 25hz at -3db
Kali sub rated at 120db it could do 110db at a flatter frequency responce then 120db
That requires a wiim amp or streamer to have peg and room correctioon with a good mic OP don't have that
Mabye a speedwoofer 10E in a corner can do it ?
Alto TS 18S rated at 29hz -3 db + 137db, when adjusted max spl might be only 120 db max but if specs are true (2500 watt peak, 18" (-3 dB): 29Hz - 100Hz) it should then do 25hz -3db when adjusted
Again requires op has some kind of eq or room correction
Big and power full but not super expensive https://www.thomann.co.uk/alto_ts_1...LCJjdXJyZW5jeSI6NCwibGFuZ3VhZ2UiOjJ9&reload=1
You have to take the room into account the room with a subwoofer, as it makes a big difference as to how low it can go. (If your looking at specs, look for in room response, not the standard response)
Bill
Thanks (again) for the input guys. Bottom line though (or one of them!) is that the subwoofer must be available on Amazon (in the UK): buying from anywhere else presents too many potential problems if I need to return it (for one thing, I live in a small village - and I don't drive).
If anyone has the time and inclination to look on Amazon and say what you think are the most suitable choices (bearing in mind the that listening to organ music would be the main incentive to buy a subwoofer at all), that would be most welcome. Maybe the ones I listed above are not as good as they initially appear, when you delve into the 'deeper' specs.
I haven't bought a subwoofer for some 35 years, so am a bit 'out of the loop', to be honest! Doubt I'd spend over £500, absolute max. 🙂
My listening room is not overly large BTW - about 20'x12'
