John Duncan said:Craig M. said:For some reason this springs to mind. Clicky. That is how to compare stuff - level matched direct comparison.
Ah, the bus has arrived...
Brilliant.
BigH said:John Duncan said:Again you're only focussing on dynamic range. Since distortion is the enemy of everything and measurements are all that matter, perhaps you could find the THD of an average AV receiver compared to a similarly priced stereo amp from the same manufacturer?
So SS amps are much better than tube amps then?
rendu said:Regarding the test of Craig m. it is very interesting indeed. My thought would be that with that level of speakers you can probably plug a "potato" with cables and it will still sound amazing... :-d
John Duncan said:rendu said:Regarding the test of Craig m. it is very interesting indeed. My thought would be that with that level of speakers you can probably plug a "potato" with cables and it will still sound amazing... :-d
Nah, the passive crossover will mean it all sounds like mush...
The_Lhc said:John Duncan said:rendu said:Regarding the test of Craig m. it is very interesting indeed. My thought would be that with that level of speakers you can probably plug a "potato" with cables and it will still sound amazing... :-d
MASH!!!! You HAVE to say MASH there!! Come on man...
rendu said:It is a tough question indeed. Here is another thought...
Could it be that the way that music is recorded is very different than the way that movies are recorded? The listening experience that each of them tries to achieve is completely different. If you have 2 different types of recordings to suit different purpose and you use the same machine for both, it is probably difficult to meet all the requirements.
Cinema is designed to create a 3D soundstage and get you involved in the action, the some requirements could be: clinical detailed sound, mid equalization range for voices, 3D expansive soundstage, bottom end attack for action and dynamics. The music on the other hand requires different features, musicality, focus, punch, imaging, timing, grip, drums, and most important, beat etc. When preamp section is designed to do very well at movies and get the best of those recording, I beleive that it is very difficult that the same preamp can also fit music. Same dress can not fit both. For example one caracteristic of my AVR is the 3D expansion soundfield, it is enormous. When you apply this to music, it sound nice but it is another story, it is not stereo sound... it does not work. Same as when I play Rianha and instead of fast punchy drums I get explosions.....
It seems that AVR is finding ways to improve this so please I hope nobody takes this as criticism to any particular product.
John Duncan said:The_Lhc said:John Duncan said:rendu said:Regarding the test of Craig m. it is very interesting indeed. My thought would be that with that level of speakers you can probably plug a "potato" with cables and it will still sound amazing... :-d
You are right. He is feeding me the lines and I am missing them.
Andrew Everard said:Overdose said:Given that movie soundtracks generally have a much greater dynamic range than purely music recordings
Is that a given?
steve_1979 said:IME movies almost always have more dynamic range than music does.
steve_1979 said:Andrew Everard said:Overdose said:Given that movie soundtracks generally have a much greater dynamic range than purely music recordings
Is that a given?
John Duncan said:steve_1979 said:IME movies almost always have more dynamic range than music does.
Mine too. But it's not all about dynamic range is it
manicm said:Overdose, read my first reply to you. I cannot explain scientifically but I think it's pretty logical. To simplistically summarise, why an AV amp may not sound good with music is because with movies you're 95% being indulged in 'loudness wars', which is more welcome when viewing, but not always welcome with non-visual listening.
To me it's as simple as that.
Mine too. But it's not all about dynamic range is it, which Overdose appears to want to make it...?
Overdose said:John Duncan said:steve_1979 said:IME movies almost always have more dynamic range than music does.
The amplifier does not differentiate between the two media types.
Overdose said:manicm said:Overdose, read my first reply to you. I cannot explain scientifically but I think it's pretty logical. To simplistically summarise, why an AV amp may not sound good with music is because with movies you're 95% being indulged in 'loudness wars', which is more welcome when viewing, but not always welcome with non-visual listening.
On the contrary, movies have a far greater dynamic range than music. The loudness wars relates to music being made to sound louder by using dynamic compression. Quite the opposite to movies.
The_Lhc said:John Duncan said:The_Lhc said:John Duncan said:rendu said:Regarding the test of Craig m. it is very interesting indeed. My thought would be that with that level of speakers you can probably plug a "potato" with cables and it will still sound amazing... :-d
However the Cone of Shame makes up for an awful lot, excellent!
John Duncan said:Overdose said:The amplifier does not differentiate between the two media types.
No, but the producers of the media do. So a soundtrack which "sounds excellent" may do so for entirely different reasons that stereo music would do; effects steering in the case of an AV receiver, and channel separation in the case of a stereo amplifier, for example.
David@FrankHarvey said:Also, it's worth noting that most music in movies is EQ'd to suit the movie or to sound much more impressive than it actually is. Listen to any 60's music in movies (for example) and it sounds great, but play it on a hi-fi system and the reality is quite different.
Overdose said:David@FrankHarvey said:Also, it's worth noting that most music in movies is EQ'd to suit the movie or to sound much more impressive than it actually is. Listen to any 60's music in movies (for example) and it sounds great, but play it on a hi-fi system and the reality is quite different.
Not being an expert, but I would imagine things to have moved on in the last 50 years or so.
David@FrankHarvey said:Overdose said:David@FrankHarvey said:Also, it's worth noting that most music in movies is EQ'd to suit the movie or to sound much more impressive than it actually is. Listen to any 60's music in movies (for example) and it sounds great, but play it on a hi-fi system and the reality is quite different.
Note, "for example". I was using 60's music as a good example of what I was trying to get across. It doesn't matter when the original track was recorded, and yes, 50 years later, even with better recording techniques, music in movies still sounds different in movies - because it is EQ'd. Accuracy, detail, neutrality etc isn't really the order of the day here, so beats are beefed up, basslines made fatter or more prominent, and upper frequencies smoothed/curtailed. Of course, every now and again, a track in a film will sound as good as the CD.
Just to be clear, I'm talking about pre-recorded music here, not film scores.
Overdose said:provided it can properly control the speakers attached to it and not add any audible distortion
John Duncan said:Overdose said:provided it can properly control the speakers attached to it and not add any audible distortion
Shall I help you out here? The £1k Onkyo receiver quotes 0.8% distortion, the £1k stereo amp quotes 0.08%. I am going to presume that since they come from the same manufacturer, they're using the same sort of measuring tools.
Renman911 said:I wonder why the OP thinks it sounds better than the stereo amplifier then? It shouldn't.
