[quote user="JohnDuncan"][quote user="fr0g"][quote user="JohnDuncan"]OK, I just thought that from the description it was going to take a long time (checking your own rips with others, I mean). But I can't get to the EAC site just now, and apocryphally it appears to be windows-only, which is a bit of a bummer.
And I want to use iTunes and an iPod, which is also quite bummer-like.[/quote]
I create FLACs and transcode the ones she wants for my other halfs iPod. I personally think lossless is wasted listening to an iPod, or any other portable. I cant for one tell the difference between one of my MP3s and a lossless on such devices.
Oh and I use media monkey to organise the iPod too...far better than iTunes.
[/quote]
OK, but personally, I'd like a one-stop shop - ie something that is audiophile
and doesn't need converting for iPod purposes (irrespective of whether one can tell the difference - I just don't want two copies). And while you mention OTs, there is the fact that my wife really couldn't be bothered using something else, now that she can do what she wants with iTunes[/quote]
Fair enough
- Stick with iTunes with error correction. Its far better than WMP anyway ,). For the most part you wont notice any difference.
Even if my other half is a well paid IT person, she hasn't a clue how to use ANY of the ripping software, or a will to learn... So I do it all, and simply want the best I can get (even if 99% of the time there is no audible difference)...I guess it's the 'knowledge of perfection' that makes me happy :=)
