- Aug 10, 2019
- 2,556
- 4
- 0
I recently posted asking whether I should or should not buy a technics amp - I bought the amp (mid 80s technics su-x350 "New Class A" amp, part of a midi system I think) and it has a volume problem. When volume is turned to minimum it says negative 70 and when turned to full says zero. Volume does change when volume knob turned, but only a slight difference from no sound at all to very little sound (about as loud as playing an ipod on full volume through a pair of headphones)
I wonder if this problem has anything to do with the "Muting"
option on the amp, or if it would be fixed easily if I had the remote (remote wasn't with it when I bought)
Any help greatly appreciated
thanks
thanks
