Starter System
darrenconnor4
19
Help,
I'm looking for a starter system for my brother. He borrowed my Cambridge Audio 641A + BX5s for a while when I was between homes and now he's gutted that I've taken them back.
He listens to lots of modern rubbish music, but quite a diverse range of modern rubbish to be fair so all rounders should be the aim...however, here comes the pinch....I'm on a tight budget. £100-£150 max to be honest. Obviously looking more at second hand kit then brand new.
I can sort him out with cables so they don't need to be factored in the budget and he only listens on his ipod/spotify so really just an amp and speakers is all he needs.
Any help/advice would be hugely appreciated. Thanks.
matthewpiano
For speakers you can't go wrong with a pair of Mordaunt-Short MS20i or MS20i Pearls and there are a few on Ebay at present. This is a very musical and solid 90s speaker that works well across a broad range of music and you should be able to pick a nice pair up for somewhere around 50 quid.
Amp-wise Rotel or NAD would do the job nicely. You should be able to get a Rotel RA01 or NAD C320 within the remaining budget and either would be a great partner for the MS speakers. In fact, that system would challenge yours for sound quality so he should be very happy with it.
davedotco
I would get a pair of Studiospares Seiwin 5a or 6a active speakers. Just under or just over £150 respectively.
Brand new, warrantees etc.
Add an AEX or even a Neet Airstreem and go wireless, depending on the iPod of course.
rainsoothe
yep
with this budget, actives are the better way. Of course, if eye-candy factor is also important - meaning that he wants to see the separates - then 2nd hand is the way. Used Rotel or NAD amps are great for this purpose.
darrenconnor4
19
Think he's after the visuals of a seperate system.
Seen a few amps on fleebay which could well go for under £50 (with postage) so hopefully i'll snatch one of those.
Any idea on the speakers?
Thanks for you help.
knaithrover
217
89
18,870
Nad C320BEE is a brilliant amp for around the £100 mark, what a bargain. I would also recommend Cambridge Audio S30 speakers or Boston Acoustics A25's which can be had for well under a ton 2nd hand - Ive had both and they are seriously good for the price
