Speakers for Primare A20 mk2
ekkn
I am new to hifi, and I am trying to get started on a small budget by buying used and good value components
Currently I have:
Primare A20 mk2 "bought used"
Arcam rpac dac
And I want to upgrade my Dali Lektor 1's
I am looking at the following speakers:
Q acoustics 2050i
Monitor Audio Bronze BX5
Please give me your oppinion.
Personally I'm more of a fan of stand mounts in this price range so would be inclined to look at something like the KEF R100.
I personally had Diamond 9.1s and then AVI neutron Vs on the end of my A20 mk2 and was looking for a better stand mount when I changed direction and got a Uniti and PMCs instead, but I only really tried the Spendor SA1s which didn't really do it for me.
Of the two that you mention though, I am probably a bigger fan of Q Acoustics than MA.
Providing you have the space I think the Q Acoustics will work really well with your Primare. They aren't quite as lively as your Dalis but will deliver a bigger, more dynamic sound with greater refinement. They'll have much deeper bass too.
Thanks for your replies.
The main reason why I wanted to upgrade my speakers was that I was really disapointed with the overall performance of the Dali Lektor 1, I had expected a lot, since the setup with the primare and the lektor 1's was a huge upgrade compared to the old sony setup I had.
So last night, after reading som reviews mentionening the importance of the speaker placement, I made an experiment with my Lektor 1's. I placed them on 2 cafe tables about 50cm from the wall and 70cm high. Before they were mounted on the wall about 170 cm high.
And I was really surprised what a difference it made, the sound was suddenly moch more detailed and dynamic, and the bass was more prenounced.
So I am gonna give my Dali Lektor 1's a second chance, and spend 75 punds on som Atacama duo floor stands instead of 600 pounds on new speakers.
