Speaker cable
Page 11 - Seeking answers? Join the What HiFi community: the world's leading independent guide to buying and owning hi-fi and home entertainment products.
I cant believe this thread is still going on.One thing i will add when i recently got my new Technics TT the power cable on it is the thickest power cable i have ever seen.Im guessing its to isolate the noise .
It's just thick to make it look substantial. Remember Monster Cables? They were just normal mains cables with an extra thick sleeve, nothing special, except the price.
The bog standard cables supplied with anything aren't the same cabling used in your walls, or anywhere outside of your home.
The cables inside your house are solid copper and not even OFC, the cables that connect to your equipment are stranded copper, which means the properties at 50/60hz are the same.
Bill
Reactions: DougK1
You 'guessed' that your thicker cable was to 'isolate the noise' Shrek.
That's what you said.
I said that suggests that thinner mains cable would have inferior noise isolation.
It does suggest that.
Don't worry about it
That is what i said Gray, and it was a guess that its to isolate interference .
Sorry i wasn't sure what you meant ,text is not always the best way to communicate .
thanks Gray 👍
Have we been applying the wrong methodology measuring speaker cables sound signature?
If you follow ASR religiously this isn't going to change your opinion but listen to this guy, this is another perspective.
This is a shift from ASR inductance and capacitance, which is their mantle. This guy speaks about the aptitude, which is the conversation that challenges the orthodoxy, some cables are faster, some slower, intriguing stuff!
No one would disagree, cables are receptors, acting as antennas for attracting RF, and longer lengths of cable, the better the antenna. Obviously cables with better insulation would render the sound more faithfully, lesser degradation etc.
View: https://youtu.be/8wVnURAckLI?si=6uqZEXl3xx4KKHCa
Over 32 speaker and interlink cables, 500 tests - as per below.
View: https://youtu.be/2kb5h1XIb-Y?si=grXtuo75kABOfnDa
fundamentally HiFi should be about the enjoyment of the music.
Couldn´t agree more!
Music is the only reason I care about hi-fi, the reason why I care for anything technical about hi-fi
It´s a means to an end.
Personally I care more and are more interested in the process of making music (being an amateur drummer) and how it ends at my house: recording, mixing, mastering etc.
It does make you wonder sometimes if that's the case for some people.
Don’t listen to your system…. listen to your music instead
Once you can do that then you know your system is working well 😉
I now don’t ever think about my system… I just enjoy my music every time I listen
Reactions: jjbomber
It's easier to enjoy it once you understand that your cables aren't making the blindest bit of difference to what you hear. I'd say that about DACs, too, but that would open up another can of worms...
Reactions: GroeneLeeuw
