Speaker cable
Page 9 - Seeking answers? Join the What HiFi community: the world's leading independent guide to buying and owning hi-fi and home entertainment products.
Perhaps in your case with Naim equipment but you are, of course, entitled to your opinion.
Thanks Al ears
I’m convinced that NACA5 cable goes very well with my XS3 amplifier and out to my ATC’s
However if I were to rebuild a SET amplifier based system again, with very sensitive speakers, I would choose TQ Ultra Black cable once again
Precisely!
Try A. Try B. Try C. Try D. Can I got back to B please? Now D? Now B? Now back to B again? Now C?
Just doesn't work. I've seen way too many people end up confused because they lose track of what they've listened to. Just compare two. Back and forth as much as you like, there's only two. Then try a different two. Or a 'winner stays on' format. Doesn't matter. Just two at a time.
Absolutely agree
I don’t think listening to more than two choices of anything Hifi related is a good thing..whether that’s amplifiers, cd players etc etc or indeed interconnect cables or speaker cables as it just gets too confusing
Now that I´m here, let me add, as reaction to the YT clip posted earlier:
If a cable changes the sound (let me be positive and say it improves the sound), your hardware (amp, speakers, cd-player, headphones) are basically flawed products. There´s something wrong with them.
I sort of agree but is it not true to say that all of those products you listed are flawed in some way else we would all have perfect products?
This would mean that by combining two or more such non-perfect products would affect the sound in either an advantageous way or the opposite of course. For example I understand that certain Naim amps have a particular configuration that requires the right sort of speaker cables?
Well yes I think my Naim amplifier sounds best with Naim NACA5 speaker cable out to my ATC speakers
I also believe that my Naim amplifier quite likes the original Naim RCA to DIN cable I’m using between the streamer and amplifier
I have other cables that I could use for interconnects and speaker cables but have found that the Naim cables work better in my system
Yes, Naim (along with Linn*) are at the forefront of British audiophoolery, and have been for decades with their proprietary connections and stacks of pointless boxes...
*Who apparently can't even design equipment to operate optimally without £1.4k power, supply "upgrades"
Yep. Silver is better conductor but it obviously tarnishes so not good
Order of conductivity from best to worst: Silver, Copper, Gold, Aluminium, Tungsten, Rhodium
Silver tarnishes, but silver oxide is interesting. It is unstable at high temperatures, so when electricity arcs across a connection the silver oxide can actually turn back into metallic silver, releasing oxygen gas (above 280oC)
Rhodium isnt that great a conductor but it is hard (much harder than gold or silver) and corrosion resistant (which means low contact resistance). Its hardness makes it very resistant to wear so it's good in high use situations. With zero oxidation.
With Naim (at least the amps from many decades ago)?
Yes, apparently.
But don´t blame or glorify the cables for it.
Just to extend on this, as per the beacon of everything science, an extraction from ASR forum.
It's about resistance and capacitance - see ASR below.
  1. If speaker cable resistance is not low enough, power output can be reduced and frequency response may be shaped by speaker impedance.
  2. If speaker wire capacitance is too high, some less-common amplifier designs (NAIM?) can react adversely, adding distortion and, possibly, damaging the amplifier.
Reactions: Al ears and woodbar
Well, if it was ASR it MUST be true!
And my wonderful new Fiio headphone interconnects have landed and cleared customs so a pretty quick job from AliX - trouble is Yodel have got their grubby little hands on the package now - what's that saying, fallen at the last fence?
Yes, apparently.
It's not glorifying the cables - it's just noting that those particular amps needed a specific cable to the speakers to get the best effect. Now whether Naim did this to get punters to spend even more "loadsa money" on cables, as well as the overpriced amps,or because their amp output stage design was flawed we do not know? You could construe that adding both "flawed" products together achieved the goal of a better sounding product?
Congrats on your purchase.
Funny when I shop from AliExpress, I normally get the Hermes courier.
Yodel is a bit shitty, fingers crossed it be delivered safely.
I'm waiting for my Meze Fukuoka headphone cables for my Hifiman He1000. Hopefully not too long to wait.
Reactions: woodbar
Yes it's funny when they send my stuff they seem to alternate between yodel (yuk) or Evri, which I think is Hermes? Occasionally I even get RM which is normally OK although with them it seems to disappear for a few days on the tracking then suddenly postie is at the door!
Yes Evri is now called Herpes, err umm, I mean Hermes.
If any rebranding is worse than the original, this is it! 😂
Going back to the 80s a speaker cable came out that had high capacitance (According to the blurb it gave you the ultimate sound but in reality was just a badly designed cable which they charged a fortune for (Pretty much the same as HI-Fi cables today) and Naim gave out a warning not to use it with there amps, as due to there low feedback design it could damage them, (Some literally did blow up the output stage when using the is cable) after having said that, any amp that is affected that bad just because of a high capacitance cable should never have been released to the market at any price.
Bill
Oh, the usual retort...even though it makes zero sense.
