Hi everyone, looking for a reasonable match for XT8F's. Contemplating a Cambridge CXA80 ... Is that a reasonable choice? Comments/suggestions most welcome.
Kind regards, G.
Kind regards, G.
CnoEvil said:It is not a match that I would make.
Tannoy can sound a little bright if matched with an amp that has similar traits.
I would be looking at Arcam or even better, Abrahamsen.
Gun Mortimer said:Hi everyone,
Many thanks for the rapid reply!
Price point ideally similar to CXA80, source will mainly be Cambridge audio CXN.
Kind regards,
G.
peterpan said:Is a Exposure 3010S2 a good amp for this speaker?
jonathanRD said:peterpan said:Is a Exposure 3010S2 a good amp for this speaker?
I had the 3010S2D on home demo last week. It is certainly more than capable of driving the XT8F's. I found it balanced (not too strong on the bass) and quite neutral - neither bright or wolly/warm. It just got on with playing the music. I suppose it also depends on what source you have.
But I really liked the 3010S2D and I would recommend you get one on home demo for a few days if you can.
Gun Mortimer said:Thanks, added to the todo list! Checking out Arkam/Roksan and looking to find an Abrahamsen - hard to find :-/
A big thank you for the rapid feedback and kind replies of all forum participants, it is much appreciated.
Kind regards, G.
Made my choice - a blind one because I don't have access to listen to the amp where I'm at. I've received my XT8F's and my CXN, waiting for my Abrahamsen to be delivered. When it gets here I'll let y'all know how it sounds. Thanks for your feedback everyone!
Cheers,
G.
