- Aug 10, 2019
- 2,556
- 5
- 0
APPLE TV
V+ Cable box
Playstation 3
Samsung M87BDX TV
I have just purchased this reciever and have set it all up as i believe correctly. All cables etc plugged in and all settings on various sources are set to send highest quality A/V.
When playing Blu Ray disc in the Playstaion i appear to be getting 5.1 sound but there is no sign on the display saying whether it is decoding Dolby Digital or DTS or any other format, just that it is Linear PCM. I am not up on much of this kind of jargeon, but am guessing it is getting the right signals ?!?!
Also with the V+ box it does not seem to be 5.1 on any of the HD channels only putting out 2 channel stereo, the box is set to output audio through the HDMI cable, should i have to output audio from the optical socket on the V box to achieve 5.1 sound ?
If anyone could help it would be much apreciated
V+ Cable box
Playstation 3
Samsung M87BDX TV
