sony KDL-40EX703 LED poor picture
Can anyone help please? the picture on my 40EX703 seems to have a slight shadow or darkening around the side edges and another one at the top. It's not blatantly obvious but I can see it. Having laid out a grand on the TV I'm a bit disappointed. Is this normal for LED's or do I have a duff?
can you see this while an image is displayed on the screen ? or only when the tv is on , but displaying no image , a blank screen ?
its unusual to see darker areas ..
clouding / backlight bleed problems normally appear as brighter areas , pools of light around the edges where the tvs lighting seeps through , if it isnt that , its probably faulty imo , and you should reject the tv ..
having said that , if it is clouding , thats a fault too imo , and you should still reject the tv ...
Thanks its there when there is an image. Think I'll take it bak to the shop
do that ,tell the seller its not fit for purpose , reject any proposals of an engineer looking at it .. get it changed or refunded ..
