Sky+HD help/General Help
Hello I have a few questions regarding sky HD and sky in general, so if possible to help i would be very grateful.
If i only want sky for setanta sports and a few entertainment channels, is it worth it getting sky HD? im aware that its a better picture than the normal sky + box but would my limited use in watching actual HD channels justify the extra money paid out in monthly bills?
also i am about to move into a new flat, so how does it work with phone lines, im aware you need a BT line but i have seen on the sky website that you can buy their line rental. I thought to get sky you had to pay bt line rental?
So basically i could get BT to activate the line and then chose sky line rental along with their broadband and phone package rather than pay BT and sky?
any help would be much appreciated.
thank you
D.J.KRIME
160
Personally I would recomend going for the HD box over the standard or Sky+ box as IMHO the picture is much better eve with SD content due mainly IMHO to the digital HDMI conection ove that of a scart one.
It is possible to have the HD box without paying the extra £10 a month for the extra HD channels if You dont really want them but You will still ge some Hd for free in BBC HD, C4 HD and I think LUX HD is also free.
Can't be of any help one the phone side of things as am with Talk-Talk but would sugest calling both Sky and BT to see what they say.
daveh75
if you get bt to connectyour line you'll be tied into a 12 month contract with them so wont be able to swap to sky for the line rental, also you mentioned your moving into a flat, if its a flat in a purpose built block that has a communal satellite system the chances are it only has 1 satellite feed to your flat so sky+ or hd wont be an option, depending on how old the block is,
the block of flats are brand spanking new.
so basically if i get BT to activate my line im stuck with them for a year at the least?
as im pretty sure sky dont do line activations,or do they?
thanks for the responses
I had the same problem when I moved into new flats a year ago.
If you've got a communal dish the sky installers won't do anything more than plug your sky box in to the wall outlet. I wanted sky+ installed but the flat only had one wall outlet. Luckily I was next to the loft space, and was able to access the Satellite LNB router and so have fed another cable through my flat to provide the second tuner input. All you need to do this this is a coax cable and some F type connectors for either end.
Having your line rental with sky is the same price as with BT so it
doesn't really matter who you're paying; £10.50 a month either way.
It's worth checking if you're in an area covered by sky broadband before you sign up: my in-laws signed up for sky plus with the intention of also taking advantage of the free broadband, only to find that sky didn't cover there street. If the flats are newly built, this will depend on who installed the phone lines: most likely BT, and they'll probably have a monopoly on the lines for 12 months to re-coup the line installation costs.
Sorry, also bear in mind that you have to have the phone-line activated before you can have the sky and broadband installed; BT can take some time in giving you an appointment, so it's probably worth contacting them first!
There's also a period of time you have to wait between phone line installation and activation of the broadband from sky: think it was a month. Can all be very tedious if you rely on internet access for working from home...
Actually, you don't need a phone line. They don't advertise it but you can pay a £25 fee to have your box activated via the dish.
I've just done it this way (having no need for a fixed line) and there are no real disadvantages save activation taking a little longer.
daveh75
trigby1:
Having your line rental with sky is the same price as with BT so it doesn't really matter who you're paying; £10.50 a month either way.
bt will have installed the lines without a shadow of doubt, as no matter what b/b phone supplier you use, theyre using bt's line and equipment, (discounting the cable companys that is)
daveh75
Beps:Actually, you don't need a phone line. They don't advertise it but you can pay a £25 fee to have your box activated via the dish. I've just done it this way (having no need for a fixed line) and there are no real disadvantages save activation taking a little longer. er you do if your a new customer, i.e not had sky before and not just upgrading, oh and you also want b/b like the op said
Another option to consider is a Freesat installation. I'm not too clued up on this, but there are probably freesat HD boxes with PVR functionality available (if not, why not!). You'd get the free HD channels and I think you should be able to pay for Setanta.(Though you'd have to check on that).
The advantage of this is no installation fees/ waiting for appointments- you could install it yourself. You could then decide about your 'phone line and broadband at a later date.
I just had a quick look on the web,
Setanta's site quotes: " I am not a Sky customer, can I get Setanta Sports?
Yes
- Providing you have a digital satellite set top box, remember Setanta
Sports is also available on Freeview, Virgin Media, Tiscali TV and BT
Vision."
I couldn't find any Freesat HD boxes with PVR- look like they've not been released yet. You'd have to route a Freesat HD box through a separate HDD recorder at present. I suppose you could get one with a DVD recorder so you could back up your programmes- that would be an advantage over Sky+/ Sky HD.
Good luck!
daveh75
trigby1:
Yes - Providing you have a digital satellite set top box, remember Setanta Sports is also available on Freeview, Virgin Media, Tiscali TV and BT Vision."
Good luck!
freesat pvr's are due out soon, setanta still isn't available o free sat afaik, i know they were in talks, and was suggested when its launched on freesat that it was gonna be a free service too
I think you've got your answer there: nice-one Dave.
If you can hold off, I'd wait for Freesat HD.
In the mean time, use those saved subscription fees to buy your beer down the pub whilst watching the England games!
I was a new customer. The reason I thought it might be useful information was because it means you then have other options; i.e cable phone/broadband.
daveh75
must have changed there policy then. you always used to have the telephone line connected for first 12months, unless you was paying full price for the box and wasn't subscribing, i,e just using it for free channels, but you live and learn!
So basically the general consensus is.
1. BT/Sky line rental is the same so thats no big issue
2. check with sky to see if its possible to get broadband from them in my area
3. most importantly check what the communal satellite will provide(basic sky,or 2 lines needed for sky+) and that should basically decide for me as to whether or not i should get sky.
I suppose if the communal sky dish is basic i could just get a new one installed!! more money out but the only other way.
have i got things pretty much summed up?
thanks to all who have posted your help has been great.
daveh75
that pretty much sums it up, would like too add though,if you do have a communal system with only 1 feed and you do go for sky hd, chances are the management co, may not let you put your own dish up as they dont usually like dishes being put up all over the place, which is why they fit communal systems in first place, i think you may be ok though as the flats are brand new, should of had a system fitted thats upto current specs i.e for sky+ and hd
so basically im praying that its a new setup otherwise im screwed for sky HD!
I hope in the near future that other channels start broadcasting in HD so i can get full enjoyment.
Now all i need to do is ask the woman at the sales office what type of satelite will be in the houses.hmm i reckon she wont have a clue! but worth a shot!
thanks for everyones help.
daveh75
it varies it may not have a communal system at all, and they may just expect you to have your own dishes installed, tbh it should be communal and as its a new block, should be upto latest specs, ie have two feeds, if it hasn't i'd be asking the developer why not.if you have no luck going down the sky route, you could always go for a freeviev box with a card slot so you can subscribe to setanta, or indeed get a setanta freeview box wont be hd though obviously
