gel said:
				ellisdj said:
			Gel you use it with IFC on Max - thats adding processing so your not seeing the true performance of the players.
Thats needs to be off to see it - I cant say that anymore times.
I also have no experience of an Oppo to compare to the Marantz but I have lived with a LX55 feeding a Calibrated LX5090. Until the 7007 I always thought it was the Plasma that had bad movement.  Once I plugged the 7007 I was amazingly surpised at how good that sets movements was.
Honest truth I have no reason to make anything up
I have owned the Pioneer 5090 and there was nothing wrong with the movement on the Pioneer 71.  Are you seriously suggesting he should spend £700 because the movement is better on the Marantz?
We are just going to have to disagree on this one.
We disagree on a lot Gel - which is good thats why I should do your TV so we can have it out in the flesh
My view is - I am always in the pursuit of perfection, anything thats not perfect I notice and then try and work on it to the best of my skill, experience and budget because it bugs the hell out of me.  Not saying my system is perfect but its getting to a very good point where I will hopefully stop spending money on it
I have not suggested the op spend £700 on anything - I have said several times you dont have to spend a fortune, but at the same time I have found the 7007 to be a much better player than all the previous players I have owned in the areas key to me
However factoring in the importance of movement when you consider when you watch a film its constantly moving then that it is an extremely important factor....
