For some reason only adverts will play via 4OD on my TV. Shows just produce the spinning buffering circle. 4OD on my other devices work fine.
I tried to un-install 4OD,but could not select the app. Others were ?
4OD was installed when purchased . Apart from restoring the TV to presets,is there another was to un-install 4OD ,then re-install ?
Thank you
Thank you
