Rotel Ra 10 or Arcam FMJ A 19 for B&W 683
atishaysingh
17
:roll: :roll: :roll: HI I am New to this Hi fi World and i am no expert. I have recently bought B&W 683 in India. I am Now looking for a amp as the speakers are yet to be delivered.(Shipment Delay) I am looking for an amp between 300 to 1000 US dollars. As per reveiws Rotel RA 10 and Arcam FMJ A 19 Seem to be good.
I want detail and excellent vocals. I have auditioned ra 10 with B&W 683 once found them to be ok but will have to audition once again before passing a verdict. I have not auditioned Arcam though and cant audition them with 683 for sure as its a difereent dealer. in India i am getting Ra 10 for 700 dollars and Arcam for 900. So i am paying a bit more for Ra 10 vs Arcam as compared to international Prices.
I am damn confused. Also open to suggetions on other amps. Also suggest a CDP matching the amp. I have my eyes on marantz 6005. Audiolab not available in India...
Frank Harvey
567
Either of those amplifiers should work well with the 683s, but I would probably edge towards the Rotel as they tend to be better than most at controlling the (sometimes slightly excessive) bass of the B&W floorstanding speakers.
atishaysingh
17
Thanks David but do you think i should consider as what hi fi says the scale in the arcam fmj a 19 and the point that it competes with cyrus 6a and naim is itself a testimony.
Yes but there is a fact that B&W and rotel share the same family which gives it may be the compatibility edge
Also what other amp would work well in your opinion. what abour cdp...
atishaysingh
17
I will figure out about the availability of creek in India. Although what about A 19 Vs Rotel do you guys agree with david or A 19 is a better choice.........
audioaddict
114
i.m looking at a quality budget amp myself and am considering the rotel ra 10 although not sure if its powerful enough for my cm1s...........other than that im considering the yamaha as500
Personally I think the RA-10 might be more of a sideways step than upgrade. I certainly recommend Rotel with B&W speakers (actually heard your CM1s with the old RA-06); you'll know some associated makes work and others don't, but Rotel and B&W does very well, for the that sort of price bracket.
Saying that I would probably be looking at the RA-12 rather than the 10.
atishaysingh
17
I might have been tempted for a ra 12 but to get things back to square 1 as arcam fmj a 19... Iis the group test winner over ra 12. Not only that it got a 4 star compared to 5 of fmj... Also in India i can consider Cyrus 6a or niam for that kind of money
People often judge a product purely on a Group Test win or how many stars a product gets. In the right set-up the Rotel will be a match for the Arcam... and you'll be listening to it in isolation, whereas the testers have numerous amps, speakers (of all prices to test against).
BigH
115
7
18,595
MUSICRAFT said:
BigH said:
MUSICRAFT said:
subaha accha aitshaysingh
Would you also consider used/discontinued equipment please?
bada mem
Rick @ Musicraft
Probably difficult in India?
Hi BIGH
Probably but good to make him aware of other options via an alternative route though.
All the best
Rick @ Musicraft
Yes I agree with that sort money a used amp. would prob. be my choice if you can find a good one. Or similar amp for much less, I even seen A19 go for £409 already.
atishaysingh
17
I am Also considering the 1520 rotel and RA 10 and Arcam A 19. Now help me lower down. The Rotel Ra 10 for 650 usd the Ra 1520 well around 1200 usd and Arcam A 19 for 850 USD. And speakers are already in as i said the B & W 683. Need some serious and worthy guidance as i am very close to the purchasing date......
