Replacement stylus or cartridge for 2004 RP3
ThreeTuns
15
9
What are the options in replacing the stylus & cartridge that came as standard back in 2004 on a Rega Planar 3? I'm looking to either replace or perhaps a mild upgrade of the original unmarked red cartridge. It is connected to a Cambridge A5 and some ancient ARC 050 with added crossovers.
Any current Rega cartridge will fit it so depends on your budget.
Not too sure you have the original fitted as it was normally fitted with a Rega R100
Does your stylus look like this?
ThreeTuns
15
9
It's definitely not one like that. Here is a pic (excuse the dust!)I think it is a Rega Bias 2 which is no longer available. Is the Rega Elys 2 a replacement for the Bias? I assume the Rega Carbon would be step down as ifs fitted to the RP1. I have seen some criticisms of the next cartridge up, the Elys 2. Would like to keep under £150 and ideally not start messing about with spacers etc
You're correct with the cartridge and yes the Elys 2 would be a good replacement if you need to stick with Rega cartridges.
VTA can be adjusted using an adjustable collar and lock nut rather than shims on that turntable, and it's well worth doing.
camcroft
748
376
19,270
See post #4 :)
1397206-9c72c8ae24896f32012c1802d0b31651.jpg I have just been in touch with someone that makes bespoke turntables using Rega parts mine actually and he said that it is not necessary to add shims to fit a VM95 ML cartridge to Planar 3 as it doesn't effect the VTA on that turntable so much that it needs adjusting.
WayneKerr
756
631
1,770
View attachment 4201 I have just been in touch with someone that makes bespoke turntables using Rega parts mine actually and he said that it is not necessary to add shims to fit a VM95 ML cartridge to Planar 3 as it doesn't effect the VTA on that turntable so much that it needs adjusting.
I do not not dispute what your colleague says, it may well fit. I read somewhere that all Rega carts are 16mm tall, most other brands are around 18mm tall, your particular AT is 17.2mm. I can't understand Rega as they seem to buck the trend regarding earthing and carts of most manufacturers, especially when you consider that their carts are AT based. The only reason I can see why they do this is to hold owners captive where only their own products will give the best performance without the need for extra expense such as shimming.
Reactions: camcroft
camcroft
748
376
19,270
Agreed my Rega arm has no shims on it and the previous owner I bought it second hand had a larger MC cartridge on it even bigger than the AT and I made no adjustments whatsoever as you know a change of mat thinner or thicker can compensate for any change in VTA as long as it not too much.
your chap is wrong in my opinion. Correct VTA is vital especially with more expensive cartridges, perhaps not with cheap elliptical ones, I admit.
The idea that VTA doesn't matter comes from Mr.Gandy himself unfortunately.
When you pay good money for an expensive cartridge you should not dismiss any factor that will enable you to get said cartridge producing it's best..
You can use the mat approach but that doesn't make the whole package sound it's best.
Most good replacement mats are thicker than what is originally fitted and this isn't what yiu want when fitting a different cartridge.
Ultimately it's down to the OPs hearing.
Not all Rega cartridges are AT based.
As you say many would consider the small difference in height to be acceptable and with a cheap cartridge you aren't likely to notice any difference, especially with likely associated equipment.
That said the original Planar 3 with RB300 tonearm will take a massive upgrade on the cartridge front.
I know I had one for many a year using a Denon DL103R.....and that needed a VTA adjuster.
Reactions: WayneKerr
camcroft
748
376
19,270
I am using the RB303 arm and the chap is basing his opinion on.
SteveR750
730
137
19,070
I'll bet that most folk wouldn't be able to better +/-1mm at the stylus using a VTA adjuster on the tonearm. The concensus of the Internet users of the VM95ML is it's less sensitive to VTA than most cartridges. Azimuth is another story, that's where the effort needs to be.
Reactions: camcroft
jordanfx
40
i opted for an ortofon blue m and added a shim to my rega planer 3 and all good
