Could anybody help outhere!Need a replacement remote for a Onkyo TX-SR606 AV reciever, got a deal on a used one and trying to get a remote from UK source. Also can you set levels without remote manually?
You will probably get better value using a Logitech Harmony remote, it will do everything the original remote would, plus easily control your other kit. You can check their website/database to be double sure your model is covered, but I would be surprised if it is not. £25 upwards from the likes of Play.com
