i have just bought rega 1 turntable with the rega brio amp, can you suggest the best compact speakers to go with this system. would be willing to pay up to £300. thanks
ontheline said:i have just bought rega 1 turntable with the rega brio amp, can you suggest the best compact speakers to go with this system. would be willing to pay up to £300. thanks
plastic penguin said:ontheline said:i have just bought rega 1 turntable with the rega brio amp, can you suggest the best compact speakers to go with this system. would be willing to pay up to £300. thanks
Generally an all rega system works a treat. There's a pair here.
Otherwise, look for Neat Motive 3, or an old pair of original PMC DB1s, although your budget is limited. Perhaps some old Mission speakers; look also at Dali Zenor, Wharfedale Diamond 9.1. Really depends on how you define compact.
Al ears said:plastic penguin said:ontheline said:i have just bought rega 1 turntable with the rega brio amp, can you suggest the best compact speakers to go with this system. would be willing to pay up to £300. thanks
Good suggestions but I would ask the OP why compact speakers (presumably standmounts)? Is this down to room size?
Always be aware that to get the best out of bookshelf type speakers they need to be on decent stands and you would have to factor those into budget if you don't already own them. This normally makes floorstanders a better deal, if you can accommodate them ( they don't necessarily take up more floorspace than a pair of bookshelf speakers on stands).
plastic penguin said:Al ears said:plastic penguin said:ontheline said:i have just bought rega 1 turntable with the rega brio amp, can you suggest the best compact speakers to go with this system. would be willing to pay up to £300. thanks
Any speaker around that budget will be a compromise. In the light of lack of information, it gets the ball rolling.
