Record Clamp for Project Essientials II
gasolin
BANNED
Was a at flea marked and looked at some records you know the big black round thing.
Found 2 special lps and bought them.... i didn't have anything so i could play the records, so asap i was home i looked at used ones (have done that on and off for 1-1½ months)
Didn't find anything i liked so i optioned to buy a new Pro- ject Essiential II (TT of the year 2015 and cheaper then a rega rp1) arriving nest week, tuesday also bought a survival kit(pick up cleaner,record brush,record cleaner and pro ject clean it)
I want a Turntable Record Player Stabilizer Clamp or mabye just called record clamp (not shure what you would call it)
Not to light not to heavy just something that works and is cheap from amazon.co.uk or some other european store that ships to denmark 50€ or 40£ would be okay
Hi. Hope you enjoy listening to your records when the turntable arrives.
There was an interesting thread recently about the benefits or otherwise of using a record clamp - you might find it worth reading before deciding whether to buy a clamp for your turntable.
drummerman said:
I would recommend a Michell clamp. Not expensive and well made.
+1
These are available on Amazon for about £34 along with others from Project and Nagaoka. All around the same price. I have used the Michell clamp in the past and can recommend it.
Al ears said:
+1
This projest is not for the tt i bought since it's doesn't have a threaded spindle (the other one is 60£)
http://www.amazon.co.uk/PRO-JECT-RC-Pro-Ject-Record-Clamp/dp/B00B4C9X2E/ref=sr_1_1?s=electronics&ie=UTF8&qid=1448803987&sr=1-1&keywords=project+record+clamp
They don't deliver to denmark but i found one in denmark i guess is with delivery included for whats equal to 39-40 £
There will be no problem about it working with the TT i bought?
