Thompsonuxb
- Feb 19, 2012
- 125
- 0
- 0
MeanGreen I don't dispute that. I understand the technics and tricks but the mixing is done in '2d' left to right.
Like drawing a 3d image on paper.
The end result though is not constant - the image between speakers is not constant, it'll even vary with volume.
Lol. ....
I don't disagree with anything you've said.
Lol. ....
MeanandGreen said:?
Thompsonuxb said:Lol..... MeanGreen, if you know how to calculate were a given instrument will appear in a soundstage, please share.
Look, the whole point about cables, bi-wiring is 'subjective' ? - for those who hear no difference, tuff. Does not make those who do hear differences deluded.
Like I've said if putting your speakers out of phase can make a difference to what you hear then the cables used can also affect what you hear.
With regards to the soundstage read Anderson's quote below. If you were mixing and recording in a studio you can mix/boost/cut any instrument you want to either the left or right channel, or even between both at once. Hence the 3D image. The highest of frequencies are the most directional and the lowest are omnidirectional. Any recording engineer will understand these principles and can mix a track to produce exactly the image they want.?
How well your system and most importantly your speakers are set up and integrate with your room will determine how accurately you will hear that 3D image at home.
I don't see how wiring out of phase making an audible difference to the sound proves anything about Biwiring or cables affecting sound?
Wiring out of phase is basically inverting the signal. That very obviously will have an effect. Biwire is electrically no different to single wire. The signal is exactly the same.
I don't dispute people hearing a difference, I'm not saying they are deluded. I do think they may be fooled into hearing a change because of psychological reasons or placebo if you like.
The stereo image thing is going off topic and I have previously said to the OP, if he is happy with his changes with the biwire then great!?
Happy biwiring and merry Christmas!?
Anderson said:?
Its not an unknown phenomena, its called a recording engineers and producers. You use a mixing desk, for each source/channel you have you can pan the sound to come from wherever you please, this allows you to create a '3D' image via stereo. Its not black magic or voodoo, I don't understand how people don't understand this.
Thanks for explaining the guys question though.
