Question
anderslund
I have some questions about setting up my Optoma HD50 and projection screen Optoma DS-9092PWC. The Optoma HD50 will hang on Vogels ppc 1500 in a room that is 3.5 x 3.5 meters and is in the basement which means it is only around 2.4 meter high. The screen will be mounted directly to the ceiling probably with hooks.
  1. Hvor far away should the HD50 be from the screen?
  2. Is there any recommendations for how high the HD50 should be compared to the screen. It will b almost impossible to place it over the screen with the setup. Is this a problem?
  3. Any recommendations for mounting a screen either with hooks or normal screws?
