Hi folks,
I've just bought the equipment in my signature. I plan to make up some speaker cables at the lengths I need and am planning the following hardware:
1) Chord Carnival Silver Screen cable, with
2) Fisual Easy Fix Banana Plugs
https://www.amazon.co.uk/Fisual-Easy-Fix-Banana-Plugs/dp/B00169BIF0/ref=sr_1_1?ie=UTF8&qid=1297025702&sr=8-1
Chord Carnival's are award winners so hopefully they will be OK. I've already bought the plugs from Amazon, however now I'm wondering if the plugs are a little too 'cheap & cheerful' for my system. They are gold plated which I thought would be all I needed, but I don't really know much about cables or banana plugs. Are these choices OK?
Many thanks
Many thanks
