Quadral Balin III
Photoro
Hello,
I found this speakers for less than 70 euros used. I was thinking of buying them, but I can't find enough info about them.
Does any of you have any experience with this speakers and can recommend them to me?
B.T.W. I am using Creative T20II speakers and I am not satisfied with the sound quality. Will this HIFI book shelves be a big jump in sound quality?
  • Manufacturer: Quadral
  • Model: Balin Mk III
  • Years of construction:
  • Made in: Made in Germany
  • Color: ??????
  • Dimensions: 275 x 180 x 220 mm (H x W x D)
  • Weight: 4.3 kg
  • New price approx.:
Technical specifications
  • Design: 2-way bass reflex, compact speaker
  • Chassis:
    • Woofer: 1x ??????
    • Tweeter: 1x ??????
  • Load capacity (nominal / impulse): 50/80 watts
  • Efficiency: ??????
  • Transmission range: 45 Hz - 22000 Hz
  • Transition areas: (for LS with multiple chassis)
  • Impedance: 4-8 ohms
ASK THE COMMUNITY
