Q Acoustic speaker connections.
Gary Pressman
12
Helli again I have a pair of Q ACOUSTIC MODEL 10101 speakers.Now can anybody please enlighten me on the best way of connecting these chaps..There seems to be two plug,screw in thingies at the back. Which cables do I use..Are they plug in cables or bare wire that a screw fastens down type connection...please can you help..
Not familiar with these speakers but the terminals on the back look standard. Any decent thickness speaker cable will do. You can either connect with bare wire and screw down or you can insert banana plugs.
It's 1010i speakers
Best is to skip the betal bracket and replace them with speaker cable or just use bi wire speaker cable for all 4 terminals
It's 1010i speakers
Best is to ski the betal bracket and replace them with speaker cable or just use bi wire speaker cable for all 4 terminals
The 1010i only have two terminals so no jumpers necessary.
Thanks guys ,I found the manual quite interesting and its sorted, just waiting for the cables to arrive and pay off the speakers from Cash Converters..
